Distributors that fit Y block 292
This might be somewhere that I cannot find it, but does someone know if any distributor bodies from later model engines (FE, FT, small block Ford, etc.) might fit the 292 Y block? I know that shaft and gear incompatibilities exist, but these can be changed/modified.
Thank You
Thank You
Thank You
Thank You
Thanks for the info so far. I am trying to put together or find a distributor that will fit a 292 that has a drive for a mechanical tach. Without spending a lot of money. I have several plain distributors for 292s, and often see reasonably priced tach drive distributors for the FT block engines. Before I go and get one and start measuring and scheming, I thought I might ask the "what else fits" question.
mikhett
12-30-2013 08:10 PM
cuellar23
06-01-2013 10:28 AM
stil190
10-26-2010 10:35 AM
JohnOB
12-22-2006 01:01 PM
272, 292, block, dist, distributer, distributor, distributors, electronic, engine, ford, fords, mechanical, small, tach, yblock
