280h cam
Old Aug 5, 2014 | 12:17 PM
william16339's Avatar
william16339
280h cam
http://www.summitracing.com/parts/cc...30-4/overview/
i i was wondering do i need new rocker arms, pushrods, and valve springs for this cam? or can i use my stock ones? i have a 428 non CJ, with d2teaa heads on her. if you guys can help me out here id really appreciate it thankyou
Old Aug 5, 2014 | 12:21 PM
william16339
never mind on the valve springs, sorry theycome with the kit
Old Aug 5, 2014 | 07:22 PM
yetiman38237's Avatar
yetiman38237
Summit has a pretty good tech line.......
Old Aug 6, 2014 | 07:41 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
That kit even includes positive-lock valve stem seals. Which means the spring seat and valve guide have to be machine to accept them and the big springs. With .530" lift, you're going to need to check clearances, valve spring bind, etc. And, because of the big lift, and the angle of the rocker arm to the valve stem at the fully compressed height, valve guides should be bronze.
At this point, it becomes a toss-up whether or not to go with Edelbrock heads instead of paying a machinist to do all that work.
Of course, you COULD go the cheapo-route - but you'll be opening it up again sooner rather than later
mercman78
Dec 30, 2006 08:54 PM
yellow72f100
Nov 12, 2006 07:10 AM
jaydgraff
Sep 30, 2006 03:12 PM
oricle
Feb 7, 2006 08:56 PM
xericx
Feb 2, 2004 08:12 PM
