Sponsored by: Real Truck
Ouch 2016 burned down
Old Aug 5, 2014 | 07:03 PM
V10man's Avatar
V10man
Aint Karma a bitch.
Old Aug 6, 2014 | 12:45 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Lets take note that the superduty was a preproduction test vehicle..
Anyone see the Chevy PRODUCTION vehicle burn on a test drive? Despite their millions of recalls
https://autos.yahoo.com/blogs/motora...191522831.html
Old Aug 6, 2014 | 12:50 AM
Grosjo's Avatar
Grosjo
That's a very hot looking truck !
Old Aug 6, 2014 | 10:30 AM
fordman19762003's Avatar
fordman19762003
with all the fabric camo on that truck it was doomed from the start. At least we know the truck will have aluminum body panels and the wheel wells shouldn't rust out in 4 years.
Old Aug 7, 2014 | 07:37 AM
droldsmorland's Avatar
droldsmorland
Even though aluminium actually forms a surface layer of aluminium oxide which protects the metal from further corrosion; sodium enhanced oxidation I would think would make it crumble as fast as metal in that particular area.
What they need to do is get rid of the dam sponge like material pinched between the inner and outer. I mean really! A sponge in a truck wheel well. Naa that will never hold moisture! WTH! That Engineering team needs to be fired and sent back to school. You'd think that since 99 that problem would have been engineered out?
Hence we Ford owners have learned to soak that area down with several products to retard the rust and maybe the retards who engineered it.
Old Aug 7, 2014 | 08:20 AM
zimm's Avatar
zimm
Maybe they started reusing the faulty alternator plug that caught superdutys on fire back in the late 90's.
I had a F350 dually county work truck go up in flames on me. Luckily we had about 30 fire extinguishers in the bed as we were doing their annual inspections that day! I went through 3 of them before we figured out we had to disconnect the battery to get it to stop.
And I hope those aren't the final production headlights- yuck.
Old Aug 7, 2014 | 09:52 AM
zimm's Avatar
zimm
Originally Posted by cattlerancher
Why would they not carry a fire extinguisher
Looks like they used one.
Old Aug 7, 2014 | 03:33 PM
arniet's Avatar
arniet
Once upon a time on the PA Turnpike, the car in front of me started smoking and we both pulled over. I used a 10# dry chemical on it (required equipment in the company car). Put it out for just a second, then it made us run away, burned to the ground. Might as well "spit" on it.
Zimm is the only person I ever head of that put one out, of course who carries three? Was it gas or diesel?
Old Aug 9, 2014 | 12:39 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
A previous 6.7L diesel Ford fire, in the current production steel body, was successfully extinguished before the truck burned completely to a blob:
Old Aug 9, 2014 | 01:30 AM
92F350CC's Avatar
92F350CC
Man, that goes back even farther than that. My 92 had the same thing happen. Luckily I caught it in time and extinguished the flames. Only damage was the alternator, so that was lucky.
Old Aug 16, 2014 | 08:08 AM
parnass's Avatar
parnass
Here is a video clip of the prototype on fire:
Old Aug 16, 2014 | 10:21 AM
redford's Avatar
redford
FTE Leadership Emeritus
Car-B-Qs happen all the time.
Old Aug 16, 2014 | 11:53 AM
  #28
Tom's Avatar
Tom
Yeah they do. I find it impressive that they're not more common with some of the fluids and temperatures that are involved.
06greenstroker
6.7L Power Stroke Diesel
Dec 7, 2024 09:49 AM
scatgo
Nov 20, 2011 10:58 PM
plowboy2155
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Dec 4, 2006 10:44 PM
Stroker_Deezel
General Automotive Discussion
May 29, 2006 07:21 AM
Finally
Apr 3, 2005 06:35 PM
