Need a straight answer...
Old Aug 1, 2014 | 04:32 PM
F150Dave's Avatar
F150Dave
Hello everyone, I recently picked up a 76 Hiboy (360/435/205/44hd) Right now the truck has 38.5 boggers and what appears to be the stock suspension/leafs. I need to replace a broken d.s. Front spring so I was looking at replacing the original equipment with a 4" lift . My question: can I run the 4" lift without changing my steering (hydro assist)? And, can I use the same spring in the rear as the front? ( I kno they are different width 3" compared to 2.3") I do plan on going to a Dana 60 and Saginaw but I need a spring and I can use all the lift stuff on the 60 later, so before I order all my stuff, will this work?
Thanks
Old Aug 1, 2014 | 05:40 PM
montana_highboy's Avatar
montana_highboy
You can, but it's less than ideal. You'll need to remove the hydro lines bracket on the crossmember and be sure the hoses have enough travel at full axle droop.
Also, the steering geometry will be stressed to the max, particularly the drag link/control valve assembly, which will be at a severe angle resulting in bump steer.
Old Aug 1, 2014 | 06:08 PM
F150Dave's Avatar
F150Dave
Thanks for the quick reply. I'm just going to replace it with a factory leaf until I gather my parts (my buddy has a 01 SD he's taking the motor out of and "selling" me the rest of the truck lol). I'm just waiting on him for the parts. A new question, can I use the steering box from his truck as opposed to a 77-79 250?
ford141
65
Jul 16, 2020 09:40 AM
william16339
Aug 27, 2019 10:35 AM
terryf150
Offroad & 4x4
Mar 6, 2010 08:23 AM
rocessk8r2
23
Aug 2, 2008 12:46 PM
tang93gt04
Dec 31, 2004 01:41 AM
