96 F-250 runs great for 15 min then it develops a miss after it is warm
Old 08-03-2014, 04:51 PM
BLK 96's Avatar
BLK 96
BLK 96 is offline
I have a 96 F-250 with stage 1 injectors, adrenaline hpop, DP tuner chip, it runs great for about 15 min then when it is under a load in drive and overdrive two of the injectors quit firing and starts shuddering real bad. I have changed the UVCH and gaskets on both sides, put my original black CPS back in, changed out the IPR with another one i had, put new o-rings on it the electrical part of it is original though. I changed out the IDM with my Dads that did not help. Then I unhooked the chip, and it still seems to do the same thing just cannot tell as much with the lower horsepower but it still shudders at WOT. I'm about to give up! Any help would be great. OH yea the oil only has around a 1000mi on it Schaeffers 15-40.
Old 08-03-2014, 05:41 PM
glovemeister's Avatar
glovemeister
glovemeister is offline
Typically associated with worn injectors. Although you stated they are new?
Old 08-03-2014, 06:02 PM
BLK 96's Avatar
BLK 96
BLK 96 is offline
They have less than 30,000 miles on them. I sent the two that was missing back to Full Force to have them fixed and they said there was nothing wrong with them.
Old 08-03-2014, 06:31 PM
Robbieo11's Avatar
Robbieo11
Robbieo11 is offline
How is compression in those 2 cylinders. Do u have any raw fuel out the tailpipe
Old 08-03-2014, 06:55 PM
BLK 96's Avatar
BLK 96
BLK 96 is offline
Old 08-03-2014, 09:14 PM
BLK 96's Avatar
BLK 96
BLK 96 is offline
I haven't checked the compression, and there is no raw fuel coming out of the tailpipe.
Old 08-03-2014, 09:54 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Have you tried unplugging the map sensor and ICP? Not both at the same time though.
Old 08-04-2014, 08:44 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel
OldWoodsDiesel is offline
have you ohm'd out the injector wiring and IDM when hot? if it truly is a miss and is not firing at all on certain cylinders when hot, it could be an intermittent wiring problem that only opens up/shorts when up to temp. there is a good write-up somewhere on the web for testing the wiring from the IDM to the injectors before replacing your IDM. i think it is from a company that remans IDM's. i'll poke around for it again, but maybe someone can beat me to it.
edit: google never ceases to amaze me. first hit on a search for "7.3 idm wiring test"
http://www.gbreman.com/techbulletin_103.html
Old 08-04-2014, 08:13 PM
BLK 96's Avatar
BLK 96
BLK 96 is offline
Thanks for finding that write up, i will try that next. Could the electrical part on the IPR be bad and cause that, when i changed the IPR shaft portion where the electrical part slides over it was real dirty. I haven't tried unplugging the map sensor or ICP yet.
Wtownjake
37
10-07-2014 08:57 AM
dwnshift79
04-29-2012 02:59 PM
tntitan00
11-10-2008 10:48 PM
Bigcat350
09-02-2008 03:44 PM
Tailspin
03-24-2008 11:36 PM
Quick Reply: 96 F-250 runs great for 15 min then it develops a miss after it is warm
