Does anyone know of a pin location for reverse in the area of the radio? I'm trying to wire a backup camera and don't want to run a wire all the way up from the back bumper...
Fuse panel, the plug on the bottom right there is a black with pink stripe wire on pin 1 (Connector C270f) this should be the reverse sense wire you are looking for. Use a meter and check voltage while in park and and reverse.
That is for my 03x and was the same for my 02 250. wire color I believe stayed the same but double check with meter before taping.
Hope that helps.
yup literally just used that wire like 4 days ago in my 03. works great
