Sponsored by: Real Truck
reverse wire
Old Dec 16, 2008 | 01:03 PM
bohiaa's Avatar
bohiaa
reverse wire
Long story short.
I'm trying to locate the reverse wire to connect my stereo in a 2000 F250 SD,
Can anyone help...
thanks
Old Dec 16, 2008 | 05:07 PM
jsimon724's Avatar
jsimon724
So your stereo only plays while the truck is in reverse? Or the lyrics all come out backwards?Sorry, couldn't help myself. Maybe someone else will be more helpful. I'm not really sure what you're asking. Sorry.
Old Dec 16, 2008 | 05:22 PM
patrickke's Avatar
patrickke
i think what he has is a truck with a backup camera in the stock headunit...but im not sure about the wire whereabouts
Old Dec 16, 2008 | 05:23 PM
taken's Avatar
taken
He probably needs the wire to trigger an aftermarket rear view camera.
Old Dec 16, 2008 | 08:50 PM
ReAX's Avatar
ReAX
2000 Ford F Series Cruise Control Wiring Information
Constant 12V+ Green/Purple or Yellow Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Red/Black or Blue/Green Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake n/a Brake Switch
Cold Side of Brake Red Brake Switch
Tach White/Pink BCM, Pin 48 of 104 Pin Connector or Pin19 if Diesel
VSS Wire Gray/Black Pin 58 at PCM Mounted through Firewall
this is the closest I could find.
Old Dec 17, 2008 | 08:01 AM
bohiaa's Avatar
bohiaa
yea that's what it is, I really didn't wanna go into the entire reason. But I forgot how some people are here.....
Was hoping some one has been there and done that b4. Guess I'll have to get out the ole tester, and just hope I have luck.
Thanks
GormGorm
Sep 24, 2012 11:24 PM
TIKT B8
Jun 17, 2010 12:37 PM
Billyk
Apr 2, 2010 08:19 PM
pep100
2004 - 2008 F150
May 11, 2008 02:42 PM
mastercaster
Apr 24, 2007 07:47 PM
