You can come over and borrow mine, Steve.
Went through leakage problem on my 86 about 11 years ago. Tried sealer,caulk etc. Turned out the windshield was separating from the adhesive holding it to the frame. Was removing the windshield, almost out and........
Had full glass coverage...guy came out to the house and installed a new one.
Many times you can pry up the trim with your hands.
Sounds like I will give it a try. The tool dosen't look like rocket science. I was just about to head out for the nite. I'll let you know how I make out. Gonna put the '86 in the garage for some other work and thought I might fix the water leak while I was at it. Thanks for the tip.
Good late morning everyone.... been busy trying to take care of ONE email for the last 3 hours this morning. At least that is out of the way just in time for some lunch.
