Dirty CAC Boot
Old Jul 30, 2014 | 12:21 AM
r___r's Avatar
r___r
Dirty CAC Boot
Off the intake spider, the hot side boot has a dirt and oily film while the cold side boot does not. The hot side boot is the only spot that I could find this.
Has anyone seen this and have an idea what could be causing this?
Old Jul 30, 2014 | 09:42 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
That is normal. The crank case has a vent, aptly named, the Crank Case Vent (CCV). See where it goes from the drivers side of the engine into the intake tube?
It vents pressure there, and with it goes some oil residue. Not detrimental to your engine. Minute amounts accumulate in the intercooler. I'm talking a few milliliters. (I'm going to pay for that, I just use the metric system at work so its easier for me.) Some people do a mod, also very appropriately named, the CCV mod.
Old Jul 30, 2014 | 05:27 PM
Icicle's Avatar
Icicle
He has done the CCV mod according to his sig.
Old Jul 30, 2014 | 06:44 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
No signatures on mobile.....
If its pre turbo it has to be the ccv. After the turbo it could be an internal seal in the turbo.
Old Jul 30, 2014 | 06:47 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
If the CCV mod is done and it is not routed back into the intake, then it is from the turbo passing oil beyond the seal. How many miles are on the turbo?
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Jul 30, 2014 | 08:48 PM
snakedoc's Avatar
snakedoc
It looks like it is the d's cold boot. I say turbo seal
Old Jul 31, 2014 | 10:43 PM
r___r's Avatar
r___r
Yes, I have done the CCV mod with Catchcan and routed back into intake. All the hose connections have clamps, so maybe I should check to see if residue is slipping past the connections?
Old Jul 31, 2014 | 10:46 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yeah we figured that out. I couldnt see your Sig.
Read what we've said about the turbo seals.
Old Jul 31, 2014 | 10:52 PM
r___r's Avatar
r___r
Odometer is just under 125,000. I'm the 4th owner. Don't know if it is the original turbo.
What is the d's?
If it is the turbo seal, how do I find out to verify it is the seal?
Old Jul 31, 2014 | 10:54 PM
r___r's Avatar
r___r
Thanks for your input Trey, Justin and Matt.
I'll be reading threads on the seal.
Old Aug 1, 2014 | 02:03 PM
Justin@DP-Tuner
PREMIUM SPONSOR
Okay, now that I know you have a catch can and it is re-routed back to the intake, I have a slightly different input.
I ran a catch can and routed back to intake for around 10K miles. For the life of me I could not figure out why I still had oil in the IC piping. Come to find out, the catch can wasn't working too well. I vented to atmosphere and all oil went away. This is with a brand new GTP38R too, btw.
So... depending on which catch can you are using, that may be the issue. I ran the TSC strainer with no additional filter besides the mesh screen it comes with. Maybe if you put more filtering material in there it would work better, but I can't say for sure.
As a conclusion, vent to atmosphere for a while and see if the oil comes back. If it does, it is for sure a turbo seal. If not, it was just that the catch can wasn't doing it's job.
__________________
Justin
www.dp-tuner.com
Old Aug 1, 2014 | 06:52 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Good catch. I skipped right over it being routed to the intake.
Old Aug 3, 2014 | 08:47 AM
r___r's Avatar
r___r
When I did the defoil mod last year; and, when the hot side boot on the IC blew off 6 months ago, I was wondering why there was oil in the CAC boots and hot side tube. Thanks Justin, I will try venting to atmosphere for a while. Appreciate the advice.
dothedew192
Oct 3, 2010 05:21 PM
StampedePSD
42
Dec 28, 2008 05:29 PM
sweetpea250
Nov 28, 2008 12:36 PM
RobertJohn
13
Feb 25, 2008 11:30 PM
repou
Oct 5, 2006 07:30 AM
