Help no headlights
Old Jul 29, 2014 | 09:25 PM
cabloom300's Avatar
cabloom300
Help no headlights
My dads 03 just started to have this issue tonight. The fog lights work but no headlights. Although if you hold the handle for the low/high beams back the headlights will turn on but not with the switch. Any idea what to look for? Thanks
Old Jul 29, 2014 | 11:20 PM
9228.bobcat's Avatar
9228.bobcat
I would start with the fuses
Old Jul 30, 2014 | 12:12 AM
alex91191's Avatar
alex91191
The most likely possibility is that the fuse has burned out. Remove the fuse and visually inspect it. If it is burnt, the filament will most likely have a gap in it, making it obvious that there is a problem with the fuse.
check out that one of the wires is touching ground or not. The most common way for this to happen is for a metal edge to rub through the insulation on the wire.
And maybe the headlight switch making poor contact.
Old Jul 30, 2014 | 01:07 AM
Yahiko's Avatar
Yahiko
For you viewing pleasure
wiring diagrams.
Enjoy
Sean
Old Jul 30, 2014 | 02:24 AM
Byooty's Avatar
Byooty
Probably a faulty switch and not a fuse if they come on the fuse will be fine.
Old Jul 30, 2014 | 07:59 AM
9228.bobcat
High beams are on a different fuse.
1979redf250
May 31, 2014 08:58 AM
manlikesford
Aug 26, 2013 07:20 PM
j7angus
May 19, 2011 06:54 AM
66f14evr
Electrical Systems/Wiring
Nov 4, 2005 01:50 PM
rogue69
Jun 6, 2003 04:18 PM
