Oil leak
Old Jul 29, 2014 | 06:50 AM
BarbToothaker's Avatar
BarbToothaker
Oil leak
Looks like I have a sizable oil leak just outside of the spin on filter. Could it be the 63 223 had a bolt on canister filter and this leak is the adaptor plate for the spin on type?
Old Jul 29, 2014 | 09:51 AM
daveengelson's Avatar
daveengelson
Not familiar with 223 filter assembly so taking a shot in the dark, occasionally find sale person pulled the wrong part, should be able to determine by checking the seal at the adapter, may have to pull the filter and measure. Also, filter can be installed too tight, or not tight enough. Had an experience where the rubber seal from the old filter remained on the block when I replaced the filter and ended up w/ double seals, a leak developed and gradually got worse.
Old Jul 29, 2014 | 01:10 PM
BarbToothaker
I will take it apart tonight, my guess from looking in the books is the adaptor plate has a gasket that has failed.
Thanks!
basskicker
6.7L Power Stroke Diesel
Mar 16, 2015 11:49 PM
ufvj217
Dec 28, 2012 04:03 PM
unhcp
Modular V8 (4.6L, 5.4L)
Oct 3, 2011 06:35 AM
alstieg
20
Oct 27, 2008 04:32 PM
lilpig88
Jun 22, 2003 08:13 PM
