oil leak
Old Sep 26, 2011 | 04:56 PM
unhcp's Avatar
unhcp
oil leak
Changed my oil last night and now I have a oil leak, it is coming from the area around the filter. I tried another filter and it is still leaking. I did some research and I think it is the oil filter cooling adapter or oil filter adapter?
I really dont know the difference between the parts
02 2002 Ford F-350 Super Duty Oil Cooler Adapter - Engine Mechanical - Flexalite | Drivewire.com
YC3Z6881DA Adaptor Oil Filter 01 02 03 04 F250SD | eBay
Old Oct 1, 2011 | 09:24 PM
LxMan1's Avatar
LxMan1
Make sure that the original filter ( the one that you removed first) gasket didn't stick to the engine. I have seen this happen and they won't seal with two gaskets.
Old Oct 2, 2011 | 01:12 PM
unhcp's Avatar
unhcp
The old filter does have it's gasket, so it is not that problem.
Old Oct 2, 2011 | 07:53 PM
LxMan1's Avatar
LxMan1
There is a gasket between the adapter and block that I have seen leak. I had to replace on on a 4.6L Cougar and 32V 4.6L Mark VIII. The 5.4L uses the same thing. Felpro makes them.
How bad is the leak? Can you see where it is actually coming from when it is idling?
Old Oct 3, 2011 | 12:01 AM
Moto Mel's Avatar
Moto Mel
I think you nailed it. I had the same problem a few years ago on my Mark VIII, I was hoping it was a bad pressure sender but it was the gasket.
Old Oct 3, 2011 | 06:35 AM
unhcp's Avatar
unhcp
ok i should know more this week, I got the mechanic taking a peak
abe
May 6, 2016 08:48 PM
'59 F100
Mar 13, 2008 11:15 PM
livinezy
1983 - 2012 Ranger & B-Series
Jan 1, 2008 05:59 PM
JClausen
Apr 30, 2007 11:11 AM
lilpig88
Jun 22, 2003 08:13 PM
