05 6.0 shuts off while driving, restarts in one hour
Old 07-26-2014, 11:10 AM
cmoerg's Avatar
cmoerg
cmoerg is offline
Ok gents thinking caps on please!
I have read a lot of posts that are similar to mine. I have a 2005 f-350 6.0 with 90 hp injectors, large htt turbo, egr/oil cooler delete, edge monitoring display, and sct programmer. I am fairly new to diesels but understand a lot more than a newb. What is going on with mine is similar to what others are having. I am driving down the road in heavy traffic and it dies like I shut it off, restarts 2 maybe 3 times then will not restart for half to a full hour. When it restarts it runs like a champ. After a hard pull (8 to 10k) if it idles to long it shuts off and will not restart for half to full hour. This weekend knowing all this I preemptively shut it off after pulling my trailer, went to restart and nothing. One hour later fired off and runs great. I have even had it shut off in traffic waited a half hour, fired it off and drove in heavy traffic for 2 more hours and runs great. I thought it was a few different things so I set my pid’s to monitor ICP pressure, ICP voltage, FICM, IPW, and here is what I get.
ICP pressure, starts at 800 and drops to steady 650
ICP voltage steady .9v
FICM v. steady 48
IPW injector pulse width. 0.0
I am thinking IPR, stc seal, or ? I never throw any DTC and everything works great. Any help would be greatly appreciated.
Old 07-26-2014, 11:25 AM
BLADE35's Avatar
BLADE35
BLADE35 is offline
HPO Problems you have classic symptoms
Standpipes,D-Plugs, leaky STC Fitting
best to replace all 3 items and use updated parts you wont have to worry about it anymore
Would be Good to verify these sensor at KOEO.Cranking,2500RPM in park A/C Off
ICP
ICPV
IPR%
And again when it wont start
Old 07-26-2014, 11:26 AM
cmoerg's Avatar
cmoerg
cmoerg is offline
is it just leaking seal or whole pump replacement?
KOEO?
I do not have an IPR PID
Old 07-26-2014, 11:39 AM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Just a leak for Now
if its a Leaky STC it my blow all the way out then its a Tow Job
usually just a Leak though
your truck has a GREAT HPOP 05 has updated HPOP
Old 07-26-2014, 11:53 AM
cmoerg's Avatar
cmoerg
cmoerg is offline
So pay the 2 hun and replace all three? should fix the problem?
Old 07-26-2014, 11:57 AM
BLADE35's Avatar
BLADE35
BLADE35 is offline
AT a minimum get some readings from gauges just to verify the issue
you do have the classic HPO Leak when HOT Symptoms though
are you doing the work???or a Shop??
Old 07-26-2014, 12:07 PM
cmoerg's Avatar
cmoerg
cmoerg is offline
I will be doing the work myself.
If I understand this correctly it is one stand pipe and one D-plug?
Old 07-26-2014, 12:11 PM
fordboy2's Avatar
fordboy2
fordboy2 is offline
Per side and the Stc is back by the oil pump. I would air test it to verify where my leak is but most likely one of the three.
schlepprock250
03-22-2016 02:14 PM
jeffy17
06-08-2014 10:55 PM
Lloyd Thorpe
09-08-2013 04:47 PM
1rosario
11-08-2007 07:25 PM
waterboy
07-17-2006 04:43 PM
Quick Reply: 05 6.0 shuts off while driving, restarts in one hour
