94 e-150 high idle and shifting problems
Jul 23, 2014 | 08:33 PM
im working on my father-inlaws van
94 e150 5.8l
it is idling high i would say in the 2000 range (no Tach) but every once in a while it settles down and idles normal
i cant find any more vacuum leaks
no check engine light
it also has a shifting problem ware it seems to be hunting gears
any suggestions
Jul 25, 2014 | 05:12 AM
You will not always get a CEL on with some engine problems.
If you can get a scanner on it, see what codes it has stored in the PCM.
From what your describing, it sounds like your having some EGR problems.
If your having EGR problems, the PCM is over compensating the lean/rich mixture, that will also cause problems with the shifting points of the E4OD.
It was best that you searched out and fixed the vacuum leaks, that's the first steps to repairs.
From there, you can check the IAC, clean/replace and the TPS, replace.
But, there is no sense in throwing parts and $$ at it until you get the codes read.
Jul 26, 2014 | 01:45 PM
There are no codes in the system
I will check the egr I completely forgot about those
Jul 27, 2014 | 08:48 AM
When the engine isn't running right the transmission won't shift right. When you get the engine fixed most likely the trans will be fine.
BikeNHV
26
Jul 22, 2017 03:01 PM
nsrailfan1
Jul 30, 2015 08:15 PM
freevan
Jul 26, 2014 02:53 PM
mcqn422
1997 - 2003 F150
Feb 18, 2013 01:52 PM
BLUEOVAL1992
Feb 28, 2010 12:39 PM
