Sponsored by: Auxito
Idle problems
Old Feb 18, 2013 | 03:38 AM
mcqn422's Avatar
mcqn422
Talking Idle problems
Any help is greatly appreciated. The idle of the truck will start to fluctuate violently after I sit for a while, I might just be sitting in park or at a redlight while in drive. If I don't try to rev it up or I throw it in drive or park it tends to shut off. It's shooting codes, left and right bank too lean......? I've replaced the Iac valve and the Egr valve and its still throwing same codes and giving me the same problems. Any suggestions...it's starting to be a pain in my $&@! Thanks
Old Feb 18, 2013 | 06:02 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
Check the wires to IAC, I don't know what their specs are, but I'd check the wires closely for breaks inside the insulation.
Old Feb 18, 2013 | 12:29 PM
Lime1GT's Avatar
Lime1GT
Originally Posted by mcqn422
Any suggestions
Welcome to the forum. All engine codes as well as the trucks year and engine size should be listed so people can help you. It's all a guess with out a starting point.
Old Feb 18, 2013 | 01:52 PM
Bluegrass 7's Avatar
Bluegrass 7
Normally lean codes are not addressed by changing the IAC or EGR.
You likely have faulty hoses or rubber parts connected to the intake manifold allowing air to enter as the vacuum pulls the crack open.
You need to supply the codes because, as you have done, miss interpeted them, and changed parts that are not the cause of the issue.
Good luck.
2000f1505.4
1997 - 2003 F150
Nov 15, 2011 09:31 PM
drabcat
Nov 20, 2010 07:24 AM
BLUEOVAL1992
Feb 28, 2010 12:39 PM
1badbaker
1978 - 1996 Big Bronco
May 9, 2008 02:12 PM
