351W running rough
Old Jul 23, 2014 | 04:20 PM
Ab73ford's Avatar
Ab73ford
351W running rough
Hey Guys
I'v got a 351 with a 302 cam in it Edelbrock performer manifold 600CFM carb.
For some reasion i can't get this thing to idle right. i have messed with the timeing, with the carb. The motor seam like it has good power
Problems
  • I'v got fuel in the oil
  • will not idle at normal rpm's
  • spark plugs are black
  • going though alot of gas
  • gas and air mix screws don't do anything
Things I have check
  1. i'v check timeing
  2. opened carb and check floats and seats
  3. replaced manifold gaskets
  4. changed carbs (neibor had an 700cfm carb)
  5. fuel pressure is about 4lbs i think if the gauge is working right
anybody have any good ideas
Old Jul 23, 2014 | 04:34 PM
gatorfor88's Avatar
gatorfor88
Sounds like the fuel pump is leaking into the block. That is about the only way to get fuel in oil, and will cause just about everything you describe.
Old Jul 23, 2014 | 04:39 PM
Ab73ford's Avatar
Ab73ford
ya i was thinking about that. its a new pump i guess it could be defect.
Old Jul 23, 2014 | 05:45 PM
Canus's Avatar
Canus
Indeed it sounds like a fuel pump problem. Also, ensure you are using the correct firing order. The early 302 used a different firing order than the newer 302 which is the same as the 351.
Old Jul 23, 2014 | 07:57 PM
Ab73ford's Avatar
Ab73ford
well I replaced fuel pump and oil. still runs like crap. when it idles it reves up (1200 RPM )and down like its going to die. I cant get it to leave out.
Old Jul 23, 2014 | 08:42 PM
0ldman's Avatar
0ldman
What carb? Sounds exactly like my Holley 600 vacuum secondary did the first time I built it, even the gas in the oil.
The secondaries were leaking constantly. I had power but it would flood out, foul plugs, etc. It flooded so bad the oil smelled of gasoline.
If it is a Holley I'd turn the rear float in until it cuts fuel to the secondaries all together, see if that corrects it. If so you need a new gasket.
Old Jul 23, 2014 | 09:25 PM
OldMetal's Avatar
OldMetal
Your either getting too much fuel or too little air, what is your vacum reading?
Old Jul 23, 2014 | 09:46 PM
Ab73ford's Avatar
Ab73ford
I am using the fireing order 15462738 the other 302's firing order is 13726548 i dont think that the motor would run at all.???
The Carb is an Edelbrock 600 CFM
Not sure what the vacuum is.
Old Jul 24, 2014 | 07:52 AM
Jklnhyd's Avatar
Jklnhyd
If your mixture screws do nothing, your power valve is blown.
Old Jul 25, 2014 | 04:41 PM
Ab73ford's Avatar
Ab73ford
I didnt think Edelbrock had power valvees? I thought that was a Holly thing. I think the air mix screws aren't working is because I can't get the idle down low enough.
Anther thing when i close the choke flap for a second the motor idels up???? I am guessing that means i am lean??? and the carb make a funny vacuuum noise that's not consistant almost like a gergal maybe i am crazy
Old Jul 25, 2014 | 05:00 PM
0ldman's Avatar
0ldman
Sounds like the carb is dumping fuel, but closing the choke should make it stall out and flood. Even the gurgling sounds like flooding.
You are correct, Edelbrock doesn't use power valves.
Old Jul 25, 2014 | 05:22 PM
Ab73ford's Avatar
Ab73ford
if it was flooding would that mean my float out of ajustment and or the seats not seating.?
Old Jul 25, 2014 | 06:55 PM
0ldman's Avatar
0ldman
I'm not completely up to speed on the internals of the Edelbrock carbs but there are usually lot of different things that can cause flooding. If the rods aren't in the jets it would be flooding and running extremely rich. I think that may have been my problem after I cleaned my Edelbrock.
Old Jul 25, 2014 | 07:43 PM
Jklnhyd's Avatar
Jklnhyd
I will read and stay quiet, lol. My bad😊
Cstout
Nov 2, 2015 07:48 PM
Skulltyrant2
Aug 9, 2008 07:27 AM
tomwrl
Dec 18, 2007 08:13 PM
lee armistead
27
Sep 16, 2006 03:59 AM
allford86
Jan 6, 2005 09:16 PM
