Converting 86 302 efi to carb
I am putting in a 302 out of a 86 f150
Into my 87 f150 that had a 351w ho with a 4bbl from the factory the 351w is in rough shape and I got a good deal on the 302. I figure the things I need will be
Intake manifold
Carb
Possible distributor
Electric fuel pump
Few questions since I have the 351 torn down would it be worth it to put the HO 351 cam in the 302 use the 351 firing order then I can also use the 351 timing cover and keep the mechanical fuel pump I want to use an aftermarket intake and a 600cfm carb and maybe some long tube headers figure the 351 cam will be a inexpensive way to gain a few horses ? If you guys have any input let me know thanks
Intake manifold
Carb
Electric fuel pump
You could use the 4180 carb you already have.
If the 302 has a blank off plate on the timing case you could use your fuel pump too.(without swapping cams, all you need is the eccentric)
A short shaft DSII distributor and 4V intake would be applications for 1985 Mustang 5.0 HO.
What I'm saying is that if the 'new' engine is running well, do as little to it as possible.
forum155pl
02-20-2009 07:11 PM
Frdbuy8589
11-05-2004 01:33 PM
the lloyd wards
03-07-2003 05:50 PM
red_rocket
07-30-2001 12:48 PM
