door tag decoder
Old Jul 21, 2014 | 09:44 PM
eriksf250's Avatar
eriksf250
door tag decoder
Can someone decode this door tag for me please?
Old Jul 22, 2014 | 12:53 PM
JEFFFAFA's Avatar
JEFFFAFA
It is indeed a 1971 F700. 361 2V.
194= the wheelbase.
F703=F700 gas 24000# GVW.
4A8=standard cab w/o butterfly hood.
55=1 speed rear axle.7.17 ratio. 17,500#. Rockwell model H170.
4=7000# front axle w/o power steering.
24000=the GVW.
182=horsepower.
3800=H.P at this RPM.
162376=tells me this was special built for original buyer.
Old Jul 23, 2014 | 08:22 AM
eriksf250's Avatar
eriksf250
thank you, and sorry for the double post
Old Jul 23, 2014 | 08:32 AM
eriksf250's Avatar
eriksf250
I will have to look up the serial number on the rear axle because it is a two speed rear that's in it right now. its got a 6 bolt center axle set up, which I've never seen before. for a Ford medium duty, I've always seen an 8 bolt Center axle setup
Old Jul 24, 2014 | 03:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F70 = F700 (gas).
E = 361 2V FT engine.
V = Kentucky Truck Assembly Plant.
L70576 = 1971.
194" Wheelbase.
COLOR code = Blank.*
F703 = F700 (gas), 24,000 lbs. GVWR
4A8: 4A = Black all Vinyl (Heavy Duty) / 8 = 81A Standard Cab.
M = Clark model 285V 5 Speed Direct.
554: 55 = Rockwell model H170 Single Speed Rear Axle / 7.17-1 / 17,500 lbs. Rear Axle Capacity / 4 = Ford 7,000 lb. Capacity Front Axle without P/S.
24,000 lbs. Gross Vehicle Weight Rating.
182 net HP @ 3,800 RPM
162376:
16 = Philadelphia PA Ford District Sales Office, where the original selling dealer ordered the truck from.
2376 = Domestic Special Order number. The truck was special ordered by the original purchaser, not "bought off the lot."
* When there is no COLOR code stamped on the Warranty Plate, the truck is painted a non standard color per the original purchasers order. This makes it a Domestic Special Order.
Eaton 2 speed rear axle:
Old Jul 24, 2014 | 04:53 AM
eriksf250's Avatar
eriksf250
Thank you JEFFFAFFA and NUMBER DUMMY, I really appreciate it. If I find the id numbers for the rear could you find out what it is? Where the axle shafts bolt on each end, there's 6 studs that hold the axle on versus the 8 stud axle I normally see used on fords
Old Jul 24, 2014 | 03:12 PM
JEFFFAFA's Avatar
JEFFFAFA
I just looked 1948-1979. No 6 stud axles listed at all. That axle came out of something other than Ford. I can't post pics like Bill can. But I can tell you looking at my fische pics, on the Rockwell 2 speeds the pinion gear is mounted high in the carrier housing. Notice on Bill's pic of the Eaton 2 speed the pinion gear is mounted low in the carrier housing like normal rear axles. Hope this helps.
Old Jul 24, 2014 | 03:18 PM
NumberDummy
Old Jul 24, 2014 | 05:32 PM
eriksf250's Avatar
eriksf250
That's the rear that's currently in it now
Old Jul 24, 2014 | 06:03 PM
JEFFFAFA's Avatar
JEFFFAFA
That look's like Bill's Eaton pic to me.
Old Jul 25, 2014 | 10:29 AM
NumberDummy
1964/72 Ford Truck Parts Catalog:
fastbub
Dec 26, 2015 05:04 PM
sambandit03
Feb 22, 2010 04:07 PM
e.alleg
Feb 25, 2009 10:25 PM
tonfro
Feb 20, 2008 04:31 AM
rowdy200
1997 - 2003 F150
Jun 18, 2003 09:55 PM
