Trailer Controller, how do you operate it?
Old Jul 21, 2014 | 03:35 PM
DawnPatrol's Avatar
DawnPatrol
Any quick tutorial on how to operate the trailer controller on my 06 F250 ??
Or is it easily explained in the owners manual (which I don't readily have with me at this time)?
Thanks
Alan from San Diego
Old Jul 21, 2014 | 03:55 PM
jswartz84's Avatar
jswartz84
Just plug in your trailer.
If you want harder braking from the trailer, press the + button until desired braking. If you want softer braking, press the - button.
The slide bar will actuate the trailer brakes without depressing the brake pedal
Old Jul 21, 2014 | 04:44 PM
Yahiko's Avatar
Yahiko
If you can wait till a bit later tonight I have a
good how to setup the braking level. I just
don't want to do from memory.
Sean
EDIT: Found an online copy. Read this link
http://www.cvsa.org/programs/documen...2001-04-05.pdf
Old Jul 21, 2014 | 06:23 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
If I'm really picky I use a gravel road near me and drive about 20 mph and manually apply the trailer brake. I up the gain until the tires skid and add a little more for pavement.
Josh
Old Jul 21, 2014 | 07:11 PM
04badford's Avatar
04badford
My add in brake controller has the slide bar and a roller depends on load, I roll adjust for stopping with out locking up the trailer brakes into a skid, take's a little playing around before you find the sweet spot with out sending you and your luggage to the dash I use the slide for Emergency's only like when some one Decides they want the same lane but slower and that's not a Thumb
Old Jul 21, 2014 | 07:38 PM
diesel_dan's Avatar
diesel_dan
How heavy a trailer do you have? For our horse trailer: about 6K with one horse and all camping supplies, etc. we set it 3-4. The Dump Trailer that I reluctantly sold last Friday, I'd go minimum of 6.
It is a pretty smart controller so you are really setting how fast and strong it reacts to normal braking. Stab the brakes and have the ABS kick in and it ignores what you have told it...
Old Jul 21, 2014 | 07:42 PM
raptor131's Avatar
raptor131
Just know that the integrated does not function like any cheap aftermarket, read up here http://www.cvsa.org/programs/documen...2001-04-05.pdf
Old Jul 21, 2014 | 07:44 PM
diesel_dan's Avatar
diesel_dan
That link was a no-go for me.....
Old Jul 21, 2014 | 08:00 PM
raptor131's Avatar
raptor131
Try now
I had to fix it,
Old Jul 21, 2014 | 08:23 PM
DawnPatrol's Avatar
DawnPatrol
Most of the time its a 3000# utility trailer for the ATV's
Once or twice a year its the big boat, around 9000#
Both of them have just the typical surge brakes.... is the controller good for any type trailer??
Old Jul 21, 2014 | 08:26 PM
04badford's Avatar
04badford
As long as the trailer has brakes and plugged in they all work
Old Jul 21, 2014 | 08:48 PM
Yahiko's Avatar
Yahiko
Sean
I take it you ran into the same problem posting that as I did.
The [TCB] in the URL mess with the way the server-side software
creates the display link.
I was doing it from my phone and it was a bit of a pain.
And the phone call right while I was getting ready to post it
really screwed up the input page.
Sean
Old Jul 21, 2014 | 11:27 PM
diesel_dan's Avatar
diesel_dan
Nope. Surge brakes are a whole different animal and you really need to know they are in good repair and working. When the tow vehicle slows, the pressure of the trailer pushing against the ball/draw-bar causes the master cylinder on the trailer to push hydraulic fluid to the brakes. They actually work pretty good when they work right.
TBC works with electric brakes on the trailer and can send a signal (more power) to the brakes, faster than the trailer even knows it needs to be slowing down, for instance, if your ABS kicks in it would do that.
Otherwise it just works the turn/stop/running lights on the trailer with surge brakes (like any other simple light hook up would)...
Old Jul 22, 2014 | 06:07 AM
dannyboy950's Avatar
dannyboy950
As diesel dan said surge brakes are a different animal. The TBS controler does nothing at all for the brakes just completes the circuit for the lights.
The controler only works on electric brakes.
Old Jul 22, 2014 | 10:10 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Originally Posted by dannyboy950
As diesel dan said surge brakes are a different animal. The TBS controller does nothing at all for the brakes just completes the circuit for the lights.
And some also run on electric over hydraulic.
