Sponsored by: Real Truck
DIY external transmission filter system
Old Jul 23, 2014 | 08:41 PM
speakerfritz's Avatar
speakerfritz
Originally Posted by Bullitt390
There has never been a flip-flop with the switch to LV in the 5r110 Torqshift. Ford made the change to Slav and stuck with it.
Josh
the second link titled NEW INFO will be of interest.
https://www.google.com/?gws_rd=ssl#q...n+damage+lv+sp
Old Jul 24, 2014 | 06:06 AM
CollinsCD's Avatar
CollinsCD
All this info is very confusing about what fluids to use in 5r110 transmissions.
I am understanding that my 2010 5.4 with 5R110W 5 speed should use the LV fluid? I am at 64K miles and due to for a change.
It seems to be the older 5R110 behind the 6.0 motors are having the issues with the LV fluid.
Old Jul 24, 2014 | 06:15 AM
redrivergorge's Avatar
redrivergorge
You should be fine with LV. If you really want to be confused have you gotten to the part about only having a heated flush machine used or drain and fill run drain and fill.
Which I'm due for so looks like my trans should get an upgrade too. Thanks trans brain.
Old Jul 24, 2014 | 06:28 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
There isn't a single 6.0 5R110 transmission having an issue with LV fluid.
Josh
Old Jul 24, 2014 | 06:34 AM
CollinsCD's Avatar
CollinsCD
Yeah, I know about the heated flush machine. No dealers around me have that machine so I will drop the pan and replace the filter. Then I will put a couple hundred miles and drain the pan again and fill with fresh fluid.
Old Jul 24, 2014 | 08:59 AM
Kdr358's Avatar
Kdr358
My 07 E350 had no issues switching from SP to LV. Still shifting like it did the day I got it with no issues.
Ozzie H.
Jan 29, 2017 10:08 AM
vancouver f250
Aug 16, 2013 10:45 AM
diesel_dan
Jul 16, 2013 10:54 PM
PirateGhost
Sep 27, 2011 08:26 PM
whporwil
6.4L Power Stroke Diesel
Aug 12, 2010 06:46 AM
