Sponsored by: Auxito
knocking noise on start up
Old Jul 18, 2014 | 08:47 PM
glemons42's Avatar
glemons42
97 ford f150 4.6 romeo. Did a engine swap with a junk yard engine, all is well, just dropped it in a few weeks ago, now im getting a knocking noise on startup and when I turn on the heater. runs great other wise, no codes. any and all info would be greatly appreciated.
Old Jul 19, 2014 | 12:00 AM
Bluegrass 7's Avatar
Bluegrass 7
There is no connection for a 'motor knock' from a heater turn on.
Maybe it's the A/C compressor you hear in some positions or even the alternator under higher loads..
Seem you have not checked it out enough to see where it's coming from.
If you don't, we can't either.
Good luck.
Old Jul 19, 2014 | 12:53 AM
glemons42's Avatar
glemons42
Good luck.
checked and replaced tensioner, replaced alternator, didn't work, still makes the knocking noise on start up and when I turn on heater. And Bluegrass that's why I cant figure it out, lol cant make the connection between the heater and the engine knock. im thinking its the water pump???? im still running the one that was on the engine when I swapped it, and all the timing, still kept all the new timing set from the old engine just in case I might need it. or it may be oil pump, but I cant seem to make the connection to the knocking when turning heater on. the only connection im making is the water pump??? What do you think?
Old Jul 19, 2014 | 12:57 AM
glemons42's Avatar
glemons42
I think im going to pull belt off and run it just for a minute tomorrow and see if I get the same knocking noise, that will tell me if it is in that area??? what do you think?
Old Jul 19, 2014 | 04:13 PM
vaper's Avatar
vaper
I would check for a rattling PCV valve,it can sound just like an accessory drive noise.
Old Jul 27, 2014 | 09:01 AM
WuShock's Avatar
WuShock
How many miles you have on new motor?
Grasping at straws here but... Could it just be still "burping" itself and those knocks are just air pockets that havent escaped yet?
2008escape
Escape & Escape Hybrid
Jan 18, 2018 09:07 AM
silverbullet219
Modular V8 (4.6L, 5.4L)
Jan 2, 2008 06:31 PM
padrejerry
1983 - 2012 Ranger & B-Series
Nov 7, 2006 01:22 PM
motorhead_83
Mar 21, 2005 02:59 PM
Pocket
Aug 25, 2004 08:20 PM
