Running temperature
Old Jul 18, 2014 | 07:04 PM
taterwuzhere's Avatar
taterwuzhere
Running temperature
Installing an electric fan on my radiator and i cant find anything that says what temperature the engine runs its best at. I need to know in order to get the correct wiring kit.
its an 86 4.9L 4 speed if that info helps.
I'll be posting a tread on how i did it when finished.
Old Jul 18, 2014 | 07:08 PM
taterwuzhere
I typoed temperature. Is there a way to change that so i dont look like a complete idiot?
Old Jul 18, 2014 | 07:21 PM
JimsRebel's Avatar
JimsRebel
Use the EDIT button on the bottom right of the post.
I thought you would want the fans to kick on about 20 deg higher than the thermostat temp.
So with a 180 deg thermostat the fan thermostat would be 200?????
I really don't know the correct answer to this question
Old Jul 19, 2014 | 11:45 AM
taterwuzhere
what I need to know is a good running temperature for my engine.
Kits are sold like these. This one cuts on at 180 and off at 165. This is based off of the water temperature.
Amazon.com: Derale 16720 180 Degree Farenheit Single Stage Electric Fan Controller: Automotive Amazon.com: Derale 16720 180 Degree Farenheit Single Stage Electric Fan Controller: Automotive
You can buy them with different ranges or an adjustable one. I personally just want to buy one with a good preset range, to save the hassle of adjusting and for the cheaper price.
Old Jul 19, 2014 | 11:47 AM
taterwuzhere
And my temperature typo is in the thread name
Old Jul 19, 2014 | 11:55 AM
JimsRebel's Avatar
JimsRebel
After EDIT ... click on Go Advanced
Old Jul 19, 2014 | 12:03 PM
taterwuzhere
Thanks jim!
Old Jul 19, 2014 | 12:47 PM
AbandonedBronco's Avatar
AbandonedBronco
Yup, you have a certain amount of time after you make a post that you can edit the title.
As for the temperature, the stock thermostat is generally 195°. I don't think engine temp is as critical for a non-computer controlled engine, so something in that range, I would think, should do you just fine.
Old Jul 19, 2014 | 04:15 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The fan sensor in the radiator should be set for around 180, if you are running a 195 T-stat in the engine. Lower temp stat, would need a lower setting for the sensor.
The sensor is reading the temp of the coolant in the radiator, if it is too warm, it cannot absorb enough heat to keep the engine cool.
Old Jul 19, 2014 | 09:24 PM
bill06447's Avatar
bill06447
Well, as an example, the 96 Caprice 9C1 I used to have, had electric fans, with a 195 t stat the fan was set to come on at 240 and shut off at 220. The 94 Mustang 3.8 I presently have will come on at 220 with a 192 t stat. A 200 switch-on seems kinda low and would pretty much have the fan running full-time. Of course, if you have AC you need a provision to turn the fan on whenever the ac is on ~Bill
Old Jul 19, 2014 | 10:14 PM
Rogue_Wulff
I bet those sensors were in the engine, rather than the radiator.
Where the sensor is located, engine vs radiator, has a lot to do with the required temp setting.
In the engine, the temp should be 20-30 degrees higher than T-stat.
In the radiator, it should be 15-20 degrees cooler than T-stat.
Yes, with A/C, the fan should run while the compressor is engaged.
reed1951
29
Jun 27, 2018 07:50 PM
85bobtail
Mar 15, 2012 07:29 AM
Showpanther
Aug 15, 2011 12:35 AM
Duramaxfanatic1
Jan 31, 2011 09:01 PM
kens72highboy
Jun 22, 2004 10:51 AM
