Recently built a test stand for a 300-6 with a plywood wiring panel on the side.
The stand is mounted on 6" dia rubber caster wheels so it can be moved around.
Use a glass pak muffler.
Wide Bronco radiator is mounted to the frame with a 12 vdc auto electric fan.
Use stock engine mounts.
The C6 is mounted to the 300-6.
Any pictures / dimensions / plans?
I have some ideas but it's always nice to steal, um I mean pay tribute to, other's work...
i built one out of some scrap wood i had in a pile by my shop. i'd be happy to take measurements and shoot them your way if you like. broke in my 300 i built for my 69 f250.
Measurements and pictures would be excellent. I have an idea of what I want to do, but seeing what others have done might save me some time and prevent going in the wrong direction!
Thanks!
