Tach Lead
Old Jul 17, 2014 | 11:16 PM
88/90f-250IDI's Avatar
88/90f-250IDI
Tach Lead
Does anyone know where the tach lead is at on an 88 7.3? My tach in my truck doesn't work because I changed the cabs from a 250 to a 150 cab and I don't know where the tack lead is from the 7.3. Any help would be useful. Thx
Old Jul 17, 2014 | 11:24 PM
Macrobb's Avatar
Macrobb
Um, the tach sender is on top of the IP gear cover(this has the oil-fill cap on it). It has two wires coming out of it, and it screws into the drivers side of that cover.
Old Jul 18, 2014 | 04:36 PM
88/90f-250IDI
Is one hot and the other ground or will they both be hot? I appreciate the response.
Old Jul 20, 2014 | 10:16 PM
Macrobb's Avatar
Macrobb
The sender produces an AC signal, so they will both be 'hot', though the signal is extremely low.
Which way you hook up the wires from the sender to the plug does not matter.
However, one of the two wires going from that plug to the tach is grounded, which makes the other one 'hot'(varying from + voltage to - voltage) with respect to that ground.
Old Jul 22, 2014 | 10:08 AM
ifrythings's Avatar
ifrythings
Gasser tachs will NOT work with are tach sensor, if you swapped wiring and cluster from a diesel you should be fine.
03trueblue
Aug 26, 2012 09:30 AM
ford-lover1995
Apr 3, 2011 03:10 PM
rmalottwtes30
Dec 2, 2008 10:23 PM
f150_on_32s
1997 - 2003 F150
Mar 24, 2003 01:50 PM
