tach only works sometimes
Old Apr 3, 2011 | 01:50 PM
ford-lover1995's Avatar
ford-lover1995
Question tach only works sometimes
my 82 f100 tach only works sometimes can anyone help, like sometimes it will work perfect, and sometimes it wont even move at all, here latley it hasnt worked a bit. is it in my wiring, or what?
Old Apr 3, 2011 | 02:29 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Factory tach, or aftermarket? Kinda important detail that got left out.....
Old Apr 3, 2011 | 03:03 PM
ford-lover1995
factory tach, sorry
Old Apr 3, 2011 | 03:10 PM
Rogue_Wulff
Ok, under the hood, near the DS2 module, there should be a plug with 2 wires (1 green, 1 black), if this is a 6 cyl, the black will only be on side, V8 it will be on both sides. Make sure that plug is making a good connection, as that's the tach wires. The green is tach signal, and black is the "V8 Corrector". The green wire then travels thru the harness into the cab, and to the "Tach" post of the coil.
Sycostang67
41
Dec 22, 2018 06:27 PM
blasterf150
1997 - 2003 F150
Dec 19, 2012 03:02 PM
krazeyelf
Feb 19, 2011 07:03 AM
DanClarke
Nov 15, 2002 02:21 PM
mshumack
Oct 18, 2002 08:02 PM
