That's a good idea, but it won't help solve this problem.
The temperature is getting too high in the torque converter, not in the transmission. How will you measure that? Measuring the transmission temperature won't show anything useful.
Backing a load in soft sand will get the torque converter very hot very fast. And you may not have noticed that I said it will also heat up going forward at low speed. But at least there is some airflow, in reverse you need a headwind that is going faster than you're backing to get much air over the cooler. And yes, I know about the engine fan. At low engine speeds it isn't doing much at all. As the trans gets hot it doesn't engage the fan clutch until the engine gets hot. And that's usually too late for the transmission.
There is no headwind going slowly in forward or reverse to speak of and the average time in reverse is probably only one minute+- so there is no time for reversing to change the heat that is already there. Doing anything in sand will heat it up, that's a given.
Putting it another way; It took many miles to get the trans up to operating temp so backing up for less that a minute won't cause ANY additional heat..............(Not in the sand now.)
If there is heat build up in the TQ then that hot fluid will be coming out and going past the trans temp sensor. so yes you will see it getting hot. and yes it will show an issue. maybe ha has a plugged cooler or a dirty filter (screen) in the trans. either way we need to know exactly what the temp is. both driving down the road and backing up in the sand.
I agree and while the TC doesn't show the temperature immediately because it is the first thing to heat up it does show eventually because ALL the oil is recirculated.
So the viton seal may stop a leak at the torque converter, but the OP said he's losing fluid out of the vent tube. Any suggestions on what may cause that? I guess I would change the filter and fluid, using a synthetic ATF because it handles heat better. I would install the viton seal also, and maybe a larger cooler. If you're in the sand a lot, maybe an electric fan for the tranny cooler. If you've gone a long way thru the sand, maybe have a beer before you back into your spot so the tranny can cool a bit.
I agree with all that. I also agree with Mark that it is rare for oil to come out of the vent tube and I think maybe the oil has a contaminant in it.
Not true according to the testing I did when I was at Ford. You just are plain wrong.
Another wrong.
The hot fluid from the torque converter first goes to the coolers, not past the temperature sensor. And when operating at very load speeds with a large load the torque converter creates heat A LOT faster than can be carried away. I have seen the converter get hot enough to melt the seal and the trans wasn't up to 200F yet.
I've said all I'm going to on this subject. I'll leave it to all of you to believe who you want to believe. One of us actually knows how this works and the others just don't understand the system, but are willing to offer their incorrect views of how they want to believe this works.
Another wrong.
I will put all my eggs in Marks basket as I know he is correct..
[Not true according to the testing I did when I was at Ford. You just are plain wrong.
[/B]
Another wrong.
You still haven't explained how going in reverse for an average of one minute (not in sand) can cause added heat compared to driving forward for one minute when there is no difference in ambient airflow (non existent anyway), the converter spins in the same direction, and the fan works both ways and you never said how long that test was for. I think I am right, as least chime in on that. Average back-up time= 1 minute. Also we didn't see that test, was it an average 3 mph, one minute back-up after already up to op temp with no wind etc etc? Anybody knows riding in sand is brutal but there are many people in here that say they just backed up a little bit after a long drive and the seal started spewing oil, and I say it is because of the change in pressure while in reverse.
Brent, are you really trying to include Mark in that 90%?
It's amazing you can ignore us when we ask you to back up your claims...like when you claim something is simple physics but refuse to post said physics as proof to back up your claim...then you have the gumption to insist that Mark post proof of his information?
To quote some of the more intelligent guys here..."Wow...just wow"
Stewart
