A friend of mine just bought an 08 F250 and the front run channel is broken inside the door. The lower part where it's spot welded to the angle bracket broke and halfway up the channel it broke from stress.
Does anyone have a part number for the run channel. I think that's what it's called; the metal track that holds the rubber that the window rides in. Is that ford only or are there other suppliers?
