TRS Questions
Old Jul 17, 2014 | 11:04 AM
tractoman's Avatar
tractoman
TRS Questions
What are the symptoms of a bad, malfunctioning or disconnected TRS? I had a blown fuse the other day that caused a no power situation to the TRS and the truck seemed to shift a little weird. I fixed power problem (short in a trailer connector) and it seems to shift normally again now. I think the TRS is also the neutral safety for starting and the truck started fine but I am wondering about the feedback to the PCM if there was no power and if this situation would cause shifting issues. Fuse 5 under the hood for reverse lights is what was blown, or is this only making power for the back up lights.
Old Jul 17, 2014 | 12:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the TRS doesn't have power you will have shifting issues. Any sensor that the transmission relies on will cause issues if the computer can't see it.
No1Hookman
Feb 28, 2020 08:53 AM
grif95
May 27, 2016 06:26 AM
dmanshane
Nov 11, 2011 06:06 PM
rleptrone
1997 - 2003 F150
Aug 11, 2003 02:25 PM
