turbo PSI range?
Old Jul 16, 2014 | 02:30 PM
Superduty2005's Avatar
Superduty2005
turbo PSI range?
What is the normal turboPSI that i should see at normal speeds? Getting on the freeway it hits 21-22psi. Is that normal for a 2005 6.0l?
Old Jul 16, 2014 | 02:38 PM
Money-Pit's Avatar
Money-Pit
Mine occasionally gets up to 28 psi on a WOT run...but normally 26. Cruising on flat highway at 70 mph...runs between 5-7.
Old Jul 16, 2014 | 02:44 PM
Superduty2005
im also pushing 35's. My mileage seem to suck also...12.8 to 13.4
Old Jul 16, 2014 | 03:08 PM
69cj's Avatar
69cj
Too get the max psi boost you need to put a load on her and nail it. Max on a stock truck should be 28 and the low acceptable around 21. With stock tires on a 4 X 2 my boost cruising at 65 to 70 is about 2 to 3 psi. Pushing those 35's is not doing your mileage any good at all. Everything comes with a trade off including your driving habits. More boost means less mpg's.
Old Jul 16, 2014 | 06:24 PM
cheezit's Avatar
cheezit
You question cant really be awnsered as asked? Do you still have an egr system? Stock exhaust?
The more air you can move the more the boost number will drop.
Norma and stock truck is 28psi max.
Old Jul 16, 2014 | 07:48 PM
Jmoen7's Avatar
Jmoen7
Stock is a question asked in engine bay modifications, and not tire size either. If anything, bigger tires will increase load at all ranges, making the turbo work more. I have new 35" treadwright guard dogs on my truck and just was out romping around and i was still hitting 28 PSI on WOT. If you're only seeing 20 or so at WOT you need to either check for leaks and/or inspect the turbo.
Just want to add my mileage is 12 MPG average small trips, to work, groceries etc. Highway is 17-20 depending on headwind/hills etc. Engine is all stock that i know of, just newer stock parts.
Old Jul 17, 2014 | 02:23 PM
Superduty2005
I'm stock exhaust and under the hood. WOT....Wide Open Throttle? This might be a dumb question...do you need a tuner to roll coal or other mods? Can a stock truck make any black smoke?
Old Jul 17, 2014 | 02:28 PM
Money-Pit's Avatar
Money-Pit
Yes...WOT is wide open throttle
Normally, if a stock truck is "rolling coal"....you have a problem. So technically yes.... a stock truck can do it, but probably not because you want it to.
Old Jul 17, 2014 | 03:20 PM
Superduty2005
thanks. My 13yr old son wanted me to roll some black smoke. I couldn't make it happen. Ive only had the truck for 2 months, and finding out It has a few issues. I've changed the oil, need to flush coolant asap. Im replacing rear diff fluid this weekend.
2005 F350 6.0L 4x4 181,000 miles, 35's, Tuff Country dual steering stabilizer, front leveling kit.
Old Jul 17, 2014 | 05:18 PM
mustang_309's Avatar
mustang_309
All rolling coal does is give diesel owners a bad name and gives the EPA more reason to breathe down our necks.
Old Jul 17, 2014 | 06:55 PM
69cj's Avatar
69cj
Mustang hit that nail on the head. That's why 13 year olds don't have drivers liscenses. If you want to act like one, neither should you.
Old Jul 17, 2014 | 07:55 PM
cheezit's Avatar
cheezit
Yes you can, just get the egr valve to hang up
Old Jul 17, 2014 | 08:24 PM
cornstar6207's Avatar
cornstar6207
X2 Mustang. Rolling coal is unburned fuel, and sign of an inefficient engine.
bubbasz1
6.4L Power Stroke Diesel
Jan 28, 2013 08:02 PM
MudhenGIB
Mar 24, 2011 04:27 PM
randy450r
May 18, 2009 04:03 PM
maevans
Oct 6, 2005 08:59 PM
Navistar444
Jan 8, 2005 06:56 PM
