Stock boost levels?
Old Jul 19, 2010 | 11:11 PM
MudhenGIB's Avatar
MudhenGIB
Stock boost levels?
What should I expect under full acceleration?
I am seeing around 18-19 PSI. I do not recall what I had before the EGR delete. I am hear the "hiss" again after I release the throttle under acceleration. Next on the list is clean/rebuild the Turbo. Would a dirty Turbo contribute to lower boost levels? Cheezit mentioned it shouldn't go over 30 PSI, if it does I need to fix it ASAP, but at 18, I'm no where near 30.
Thanks,
Matt
Old Jul 19, 2010 | 11:22 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
From info in the spread sheets:
0-26= normal
27-28= severe
28+ - Alarm
Yours looks about normal. I don't know if your reading boost at WOT, or just normal driving.
Old Jul 19, 2010 | 11:26 PM
MudhenGIB's Avatar
MudhenGIB
WOT. Normal driving is minimal. Thanks!
Old Jul 20, 2010 | 12:02 AM
amdriven2liv
My boost gauge is messed up right now. I have read on here that people were complaining they weren't getting higher boost numbers on WOT. That is not higher than 21. So, your 19 on WOT might be lower than what you should expect. Maybe someone will chime in here and give us an idea of what they are seeing on theirs at WOT.
Anyone?
Old Jul 20, 2010 | 12:07 AM
amdriven2liv
Just read this on another thread, thought you might want to read it.
Originally Posted by hubler13f
I experimented with cutting EGR valve bodies off, unhooking them, installing a plate in it's place, and several other combinations before and after my EGR delete and have learned that when running stock my truck will throw a code for insufficient EGR flow unless there is a fully functioning EGR valve connected. While this code is set my boost pressure is approximately 6 psi less or about 19 psi at WOT.
As long as I have a fully functioning valve connected whether it is attached to the firewall with a plate in its place or installed in the intake the EGR code is not thrown and boost pressure is at normal levels of about 25 psi at WOT.
My boost pressure also maxes at 25 psi at WOT with a custom tune that has the EGR deleted.
This tells me that my truck only judges EGR flow by how far the EGR valve is open.
Thread this post was in:
https://www.ford-trucks.com/forums/9...ml#post8886664
Old Jul 20, 2010 | 06:47 AM
CAMPINGTOM's Avatar
CAMPINGTOM
I bet your boost is limited because of the EGR delete. Mine was. Although I didn't get any codes or CEL, my truck was in limp mode.
It gave me am excuse to buy a tuner.
Old Jul 20, 2010 | 07:14 AM
ehgeeray's Avatar
ehgeeray
I sounds like your about normal. The only way to hit 30PSI is to cruise in the highest gear at say 65mph and then step on it.... Try that your boost will be higher. probably close the 30psi.
You will never hit 30psi shifting through the gears...
Old Jul 20, 2010 | 09:04 AM
69cj's Avatar
69cj
I will get approx. 28 pulling 5er in sig. up 8% grade. Let your gauges be your guide on when to slow down and use your gears. The gears are your friend.
Old Jul 20, 2010 | 10:06 AM
EODguyJake's Avatar
EODguyJake
Fulltime INFIDEL!
Tim (npccpartsman) has been turning some wrenches for me while I'm deployed. My stocker was just removed and replaced with a new Garrett 3788VA, but with just intake, exhaust, and an SCT with ID tunes, I think he said it was making around 29lbs. It has been making that for quite some time (like 35K miles), and I've never had any issues.
Old Jul 21, 2010 | 08:45 AM
shoobear's Avatar
shoobear
I just had mine at the dealer.
Mine is 27.5 lbs
Stock is suppost to be 24 lbs.
05 F350 never chipped.
Old Jul 21, 2010 | 08:56 AM
69cj's Avatar
69cj
The factory boost gauge is sort of ambiguous in the 25 to 30 range. Not a lot of deflection there. With a factory gauge if you are not going past 29 to 30 I would not be too concerned.
Old Jul 21, 2010 | 11:07 AM
Nitrous's Avatar
Nitrous
With egr plugged in I get 26-27 psi max boost pulling my 5er uphill. With it unplugged I get 21 psi max.
Old Jul 21, 2010 | 11:35 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Strange, I am getting 30+ pulling my TT and I have not touched the EGR. I dont let it stay there but it will climb up there.
Old Jul 21, 2010 | 03:06 PM
69cj's Avatar
69cj
Sounds dangerous to me.
Old Jul 21, 2010 | 03:10 PM
02GrayPowerStroke
Yea me too. Wish I had a blow off valve set at 25 psi or less. Something that I would not have to watch all of the time.
