wiring help
Old Jul 16, 2014 | 02:18 PM
Cameo 57's Avatar
Cameo 57
wiring help
94 F350 7.3idit
I have a couple connections to make after putting heads back on.
Behind the A/C compressor there is a white/blue wire and one that is coved so I can't see the color, but similar end on it. Where do these go to?
I'm guessing the white/blue goes to temp sensor.
Old Jul 16, 2014 | 09:54 PM
Macrobb's Avatar
Macrobb
Um, there's two sensors down that side of the block -- one to the temp sensor, one to a high-temp switch(triggers check engine light when it's on). Both one-wire sensors.
Old Jul 16, 2014 | 09:59 PM
Cameo 57's Avatar
Cameo 57
Could you post a picture for me?
Old Jul 16, 2014 | 10:12 PM
Macrobb's Avatar
Macrobb
Not easily; I'm sure someone else has a picture. It's a round plug-sensor with a single screw sticking out of the center of it; driver's side front of the engine, underneath the AC compressor(above the level of the PS pump)
Old Jul 17, 2014 | 12:13 AM
Cameo 57's Avatar
Cameo 57
There is also a long black plastic tube with a 90 degree bend coming from the vac manifold on their drivers fender. Any idea where that goes? I took a butt load of pictures before taking it apart but of course these things are just out of frame.
Headviking
Feb 8, 2019 08:56 PM
pfrye2007
Modular V10 (6.8l)
Feb 27, 2018 12:00 PM
OBSHayden
Apr 1, 2015 11:46 AM
algranger
17
Mar 3, 2010 10:28 AM
redlightning93
Feb 3, 2009 12:11 PM
