front/rear axles
Old Jul 23, 2007 | 01:33 PM
78'Ranger's Avatar
78'Ranger
front/rear axles
Hey all....kind of a newbie question hear but how do I identify what my front and rear axles/diff. are? Im looking to rebuild them but I dont know how to identify them 1st....
the truck is a 78 Ford F150 Ranger 4x4.
Old Jul 23, 2007 | 01:46 PM
fordbuddy79's Avatar
fordbuddy79
Dana 44 front;ford 9" in the rear...
Old Jul 23, 2007 | 02:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The rear is easy, the front may not be.
Ford lists the AXLE code on the Warranty (VIN) Plate. This code ID's the rear axle as to type and ratio. Sometimes it ID"s the front axles on 4x4's, sometimes it doesn't.
On Dana 44 axles, the code is listed in two possible places on the axle itself. On a metal tag on the axle cover, or on a metal tag that bolts to the housing to the right (left on rear axles) of the cover. The bolted onto the housing tag is 2" long by 1/2" wide with either a Dana or a Ford axle code stamped on the tag. Don't be surprised if the tag on the cover is missing. When the cover was removed, when the rear axle was worked on, the usual scenario was to forget to reattach the tag. The bolted to the housing tags are (usually) always still there.
Post your AXLE code. I'll tell you what it decodes to.
btw: Not all rear axles were Ford 9 inchers. Dana 44's were used as rear axles on some models during the 1970's, too.
Old Jul 23, 2007 | 02:14 PM
MBBFord's Avatar
MBBFord
He did say it was a F150 4x4. I've never seen or heard of a D44 rear, but Ford did some weird things, so who knows. There might be one out there.
More than likely the truck has a Dana 44 front with a ford 9" rear both with 3.50 gears, and the rear might even be limited slip.
Look for the metal tag on the diff cover it will tell you what gears it has (IF it is still on there like NumberDummy said). A ford 9" will not have a differential cover, it is a full third member where the gears and carrier all come out.
Old Jul 23, 2007 | 04:28 PM
78'Ranger's Avatar
78'Ranger
the axle code is on the bottom of the diff. right? if so its 072, and a 10 bolt pattern, thats all I can find....thats the front diff. as for the back let me get back to you, I dont think theres a metal tag on there...
Old Jul 23, 2007 | 05:20 PM
Mil1ion's Avatar
Mil1ion
No that's not it
Post ALL the characters from the axle tag.
Old Jul 23, 2007 | 05:28 PM
78'Ranger's Avatar
78'Ranger
Where is that tag located on the axle? I was hoping to find the codes on the vin that is on the frame rail....but i cant find it for some reason...all the info i got was from the tag on the driver side door but that doesnt have axle codes....Im getting confused where these tags are...atleast I can help people once I find out tho
Old Jul 23, 2007 | 05:39 PM
Mil1ion's Avatar
Mil1ion
The axle tag is usually mounted to a housing stud (9") or inspection plate bolt (Dana)
The door rating plate should have an axle code.
see my decoder
Position #12.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old Jul 23, 2007 | 05:59 PM
78'Ranger's Avatar
78'Ranger
hahahahahahahaha....ok well long story short I was looking at the wrong plate. I found the Axle number on the rating plate...16J...
Old Jul 23, 2007 | 06:16 PM
Mil1ion's Avatar
Mil1ion
and if you scrolled further down the page you would see code 16 is 3.50 gears
Old Jul 23, 2007 | 06:21 PM
78'Ranger's Avatar
78'Ranger
yea i saw that...so does that mean its a Ford 9" rear?
The fronts a Dana 44...figured that one out
Old Jul 23, 2007 | 07:07 PM
STGFordCrazy04's Avatar
STGFordCrazy04
All 4x4 78 and 79 were 9" rear. Some 2wd trucks had D44 rears.
EASIEST WAY TO TELL. Is there a cover to unbolt on the rear of your axle? If not its a 9"
Old Jul 23, 2007 | 07:10 PM
78'Ranger's Avatar
78'Ranger
lol guess its a 9" thanks for the replies everyone!
