Blower motor
Old Jul 14, 2014 | 08:45 PM
wameyer's Avatar
wameyer
Blower motor
This recently started happening. I replaced the relay thinking that was it well... Nope. If I have the ac blower on and pop the hood and give the motor a tap it starts. If I let it sit over night have to go through same process. I thought it was resistor but from what I read that would mean only would work high or low it works in everything once I tap the motor.
Old Jul 15, 2014 | 09:07 AM
JWA's Avatar
JWA
Most likely you've got a problem with the motor itself; the tapping remakes a lost connection.
You could use a meter and look for power at the resistor connector when the motor won't turn, go through all speeds to make sure the dash switch is working too. If power is available at all terminals in sequence then I'm right back guessing its the motor.
Good news is they're not horribly expensive or difficult to change.
AikenRooster
May 25, 2018 08:24 PM
captain2207
Aug 25, 2013 02:50 PM
lumpy76
Jun 1, 2011 03:33 AM
ErrorS
1978 - 1996 Big Bronco
Feb 9, 2010 07:07 PM
Blakes3GreatDanes
May 8, 2008 02:13 PM
