Front blower motor
Old May 6, 2008 | 10:56 PM
Blakes3GreatDanes's Avatar
Blakes3GreatDanes
Front blower motor
The front blower stopped working, I can still use the rear blower heat/ac and I can feel a some air moving through the front vents while driving, but blower motor wont come on. I checked both fuses #22 under dash and I think #109 under the hood. Hope someone can help.
Thanks for your time
Blake
Old May 7, 2008 | 09:21 AM
JWISE's Avatar
JWISE
My squirrel cage broke of the motor itself, the blower motor is fairly easy to take off and check, open hood it is on the left side passenger side, it could have seized up, it is held on by 4 or 5 screws, I forget,
Old May 7, 2008 | 07:34 PM
CanadianSmokie's Avatar
CanadianSmokie
My front blower only works on high...is that a fuse issue or something to do with the switch?
Good to know the blower motor is easily accessable. I had an Acura Vigor that was a major pain to get at the motor.
Old May 8, 2008 | 02:22 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Had this happen a couple of months ago to me to. Went to Auto Zone and I think 50-70 dollars later and about 1 hour and I was working again!
Old May 8, 2008 | 03:04 AM
bigunred's Avatar
bigunred
Also had mine just die one day easy fix and cheap too.
Old May 8, 2008 | 09:38 AM
JWISE's Avatar
JWISE
I dont know what is easier checking the switch or changing out the blower, the motor is 2 speed so it could be the motor, when/if you change it, make sure you dont break the plastic squirrel cage that goes on motor, you can only get that at the dealer, That is what happend to me anyway.
Hope you find the problem
Old May 8, 2008 | 01:08 PM
Blakes3GreatDanes
After I pressed the harness on the motor its running again, go figure. thanks for the replies.
Blake
Old May 8, 2008 | 02:13 PM
JWISE's Avatar
JWISE
Blake
Was it the harness on back of the motor?
Blakester122
Sep 1, 2015 10:51 AM
OkieFromMuskogee
Jun 22, 2015 05:09 PM
OkieFromMuskogee
Jan 25, 2015 07:23 PM
blake2182
May 5, 2011 09:09 AM
kenworthfan
Nov 3, 2007 05:12 PM
