Suspension upgrades for truck camper
Good morning! Bought a 2002 V10 F-250 Lariat SD ~93k miles a few weeks ago. Live in Colorado and looking to put a truck camper on her before the fall and would like to start beefing up the carriage. Looking for any experiences/pointers.
Do I need to upgrade both the front and rear sway bars, or only the rear or front?
Thinking of adding airbags to the rear. Do I need inboard compressor? Has anyone used timbrens instead of airbags? +/- of either?
Do I also need to upgrade shocks? Front and rear?
Should I consider upgrading the alternator?
I am planning to start with the basic upgrades and then add on as time/$$$ allows.
Any thoughts/experiences are appreciated!
THANKS!
PT
THANKS!
PT
My 2011 F250 has the camper prep, which includes rear stabilizer, +1 coil springs on the front and overload leaf on the rear. I do not have a camper, but it is only rated from ford at around 2400 lbs. I see plenty of large campers on F250's but I don't see how they do it while staying even close to the payload ratings.
We had a big truck camper when I was a kid, and what I remember is that rig feeling like it was going to tip over all of the time! Front and rear sway bars would be #1 on my list followed by air bags. I do have bags front and rear on my truck and they level it up nice when loaded. The front bags are only aired up past a few pounds when I have the plow mounted.
Not sure on the sway bars. Wouldn't hurt to go over the suspension for worn bushings, joints etc. Air bags are nice because you can adjust them to your liking. The on board air makes this very easy plus you air for other things(big, get the f out of the way, horn ) At 93k miles, change the shocks. I like the Monroe Magnums. Alt should be fine just use an isolator between the truck and camper batteries. Be sure that the wheels and tires are the proper load range. If you plan on keeping the camper in the truck then I think I would get it aligned with the camper on.
I would recommend checking out the TC section on RV.net, quite a bit of info on there especially if you have not bought one yet.
Weight is going to be a big factor which if you can stay under the 2500lbs loaded would be a good starting point (some will say even that is to much) as to what upgrades you will need to do, quite a bit of aftermarket upgrades available for our trucks.
Is yours a long bed?
The "hooked up separate" recommendation is important... Do not "T" the left and right together. When a top heavy load leans it will make it worse. I opted to terminate the bags at individual schrader fittings in the bumpers, and keep a small portable compressor in my truck. I didn't want the hassle of installing the pump and gauges.
Not all F-250's have the overload leaf springs, I'd certainly make sure I had that. Air bags, with independent air circuits are great to have, as mentioned above. I like Rancho RS9000 shocks for their adjustability. What's the capacity of your alternator now? You might be OK there, a truck camper really doesn't have a huge electrical load.
-Joe
-Joe
Thanks for all the great info.
I have yet to buy a camper, but decided on the 250 crew cab standard bed after visiting a camper convention in February. Factory alternator. Has rear leaf spring assists.
Have heard/read several recommendations per the Rancho RS9000 and RS9000XL shocks. Any downside to putting XL's on rear only?
The airbag pointers are great info! Has anyone used Timbrens instead of airbags, +/-? Airbag brand recommendations? I hear Firestones are pretty good, some say it doesn't matter what brand...
Any thought/experiences about bar diameters per Front/rear sway bars? 1 1/4" front, 1 1/2" back?
Thanks for the info/experiences!!!
PT
PT
Still learning and looking at what's out there. Will most likely buy used.
Thanks!
PT
