4.9 Water Pump Help!!
Old Jul 12, 2014 | 06:56 PM
Memphis_Sean's Avatar
Memphis_Sean
Well, my truck was running pretty hot, so among other things I swapped out the stat and WP. The old stat was in backwards
WP...I bought a NAPA Reman by Cardone...when finishing-up the install one of the hub holes stripped out. I had to get the truck back on the road, so I finished it up. What should I do...tap the hole,,,pull it and replace it or get another brand. Does anyone make a good WP for the 300/4.9??? Thanks!!
Old Jul 14, 2014 | 03:46 AM
oneowner83's Avatar
oneowner83
I would recommend the Ford/Motorcraft brand.....I still have the original WP in mine after 31 years and 180,000 miles.
Old Jul 14, 2014 | 07:14 AM
Rogue_Wulff's Avatar
Rogue_Wulff
I don't bother with reman pumps any longer. 99% of the time, there's a new pump available for not much more money, and you don't have to deal with threaded holes that are buggered up.
Cardone used to be a decent rebuilder. These days, they are almost a reseal/repaint outfit, and they send everything to mexico for "rebuild".
Old Jul 14, 2014 | 11:30 PM
Memphis_Sean
Update: I installed a New Duralast WP and so far so good. It seemed to be a quality part.
Old Jul 16, 2014 | 07:34 PM
OldMetal's Avatar
OldMetal
Replacing the pump would be best but if you don't want to do that I would helicoil the bad thread hole
Old Jul 16, 2014 | 11:11 PM
Memphis_Sean
Radiator hose spring...what are your thoughts?
nrogers130
Apr 6, 2015 06:49 PM
Grendelx
Sep 25, 2011 12:28 PM
PaulzF150
Jan 14, 2011 10:36 PM
DAVID'S97F250HD
Oct 14, 2010 11:18 PM
Uzumati
Nov 9, 2006 09:23 AM
