Engine swap ideas
Old Jul 12, 2014 | 12:32 AM
jigs-n-fixtures's Avatar
jigs-n-fixtures
Engine swap ideas
I have 69-F250, with the F350 springs under it. The original engine is a 360, backed by the C6. My dad bought it new, and I'm the second owner. Basically it hasn't been worked on by anyone beside the two of us, and is basically a well worn original truck.
I'm getting ready to do a restification on it, and am considering an engine swap. I haven't kept up with the newer engines/transmissions and am wondering what combination it would make sense to put in it. I would prefer to stay with a Ford power train. But I'm considering a pre-97 Dodge/Cummins 12-valve as a potential option.
So, any ideas? Kits available, or good magazine articles?
Old Jul 12, 2014 | 01:11 AM
351Cleveland C4's Avatar
351Cleveland C4
Cummins swap would easily be the most powerful and efficient engine. But probably the most difficult swap. But it's been done before.
If you have a FE motor. The easiest swap would be to a 390 or a 428. But those are still "old tech"
If you want newer efi style engines, look at a 5.8 or 460 from a early-mid 90s f250
Old Jul 12, 2014 | 04:26 AM
jowilker's Avatar
jowilker
JnF, What is wrong with 40 years of what brung ya here. Pull the engine tranny, rebuild them both, maybe stroke the FE up to a 390. 410, or bore it out to 428. You will have something that will pull and be good for another 40. That will give you the most for the least.
John
Old Jul 12, 2014 | 02:25 PM
f100today's Avatar
f100today
Cummins swap. Best power and gas mileage by far. Cheap tweaks on a P-pump cummins and you have 300 hp and 600 ft lbs tq with 25 MPG to boot.
Old Jul 12, 2014 | 02:52 PM
blue04.5's Avatar
blue04.5
Cummins for sure if you go diesel.
What is your budget, and what are your plans for the truck? If you're not going to drive it much once the restoration has been completed you could probably freshen what you have, if it will be a daily driver I think the cummins is a great option. Gas cant do what diesel does for power and mpg.
Depending on your budget, you can get a crate coyote 5.0 for about 6k as a gas option to stay ford powertrain. Of course you will need auxiliaries to go with it.
Ford Racing Coyote 5.0 4V 412HP Mustang Crate Engine M-6007-M50 - Free Shipping
Old Jul 12, 2014 | 04:14 PM
JEFFFAFA's Avatar
JEFFFAFA
John
2X John. IMHO:
1. The truck's staying Dad's/yours and so would the block and tranny.
2. You already own them.
3. Tell me 410,427,428 aren't "cool" numbers.
4. Holley makes fuel injection for 'em. It's not done yet but this is mentioned in HioSilver's build. Read that.
5. Eddy makes some good pieces for a FE motor.
6. No modifications necessary to slow you down. 'course you do lose the Fun Factor here.
7. You can stick the money saved in to a Gear Vendor's O/D.
Old Jul 12, 2014 | 04:52 PM
Aesop's Avatar
Aesop
I am doing a 460/ZF5/NP205 swap. Cheap power. If I had the funds, I would do the Cummings swap.
Old Jul 12, 2014 | 05:46 PM
HIO Silver's Avatar
HIO Silver
360FE topped with an Edelbrock E-Street EFI and backed by a Tremec TKO-500 (5-speed).
Old Jul 12, 2014 | 07:15 PM
6t6merc's Avatar
6t6merc
I love the Cummins - although I think the 4BT is the better choice for our trucks - but you can add 100 cubic inches to your FE for much less money than a Cummins swap, and still have a few bucks left over for gas.
Eric
Old Jul 12, 2014 | 07:37 PM
BruteFord's Avatar
BruteFord
You're missing the single biggest aspect, what do you and your father want? Budget?
Personally a truck with that much family history I wouldn't do anything but up keep/restoration and minor improvements that made it more drivable/useable.
If you really want to convert it to diesel then I very much disagree with everyone in this thread including you. Much easier and more authentic to stay ford and the IDI platform is a clear choice. A simple old school diesel like the 6BT Cummins but in a much more, cost effective, drivable, convertible, stock ford, and v8 version. Came stock with a tough overdrive manual or automatic. They are harder to make huge power with(over 1000ft/lbs) but the power that is made is much more usable.
I'm sure there are better examples out there but I just stumbled on this one.
https://www.ford-trucks.com/forums/1...-pictures.html
Old Jul 12, 2014 | 08:29 PM
blue04.5's Avatar
blue04.5
How does a idi have more usable power than a cummins? At their highest factory output the idi made 388lbs tq with a turbo, the cummins started with 400lbs and was available up to 440.
idi with turbo - 190hp@3000rpm/388tq@1400rpm
cummins - 215@2500/440@1600
Not meant as an argumentative post just curious is all?
Old Jul 12, 2014 | 08:57 PM
BruteFord's Avatar
BruteFord
Wider flatter power band and better timing control, the Cummins in particular with a P-pump and turbo is peaky with minimal timing control. The IDI with the stanadyne rotary pump has a more even and controlled fuel and timing curve. And the IDI platform with it's V8 design, lighter reciprocating mass and higher flowing heads will tend to spin better.
Yes the stock IDI is a dog compared to the Cummins but the platform is solid and the aftermarket is there to rather easily make good power. Yes with a huge budget and max power goals you're better off with a Cummins, they are stronger and a P-pump will put out massive fuel. To be "cool" spending a lot of money to spin tires or do tug a wars on youtube while blowing tons of smoke please use a Cummins. But in an older SRW Ford for actual driving for moderate or low money the IDI is better way to go.
It's like the difference between putting a 351 or 426 Hemi in a 65 mustang.
EDIT
Actually the proof is right there in your post, look at the RPM ranges between peak TQ and HP. The Cummins is 1600 and 2500, only a 900 RPM range. While the IDI is 1400 and 3000, a 1600 RPM range. It's area under the curve that really matters, not the peak of the curve.
Old Jul 12, 2014 | 10:22 PM
blue04.5's Avatar
blue04.5
Thank you for taking the time to reply.
Old Jul 13, 2014 | 06:38 AM
eclectix's Avatar
eclectix
I have a somewhat similar problem, a 68 f250 4x4 with a 360 and a 4 speed (borg warner t18?) transmission. I was looking for engine options. two that came up are a dart aluminum smallblock 427 and a LSx. I imagine the dart would be less trouble-- perhaps it would just be able to use stock I-6 mounts(?); however, is there a way to adapt it to the 4 speed transmission or must I get a new transmission and if so, which , and how much additional trouble would it be to install?
To the OP, if I may (off topic), how much trouble was it to swap 350 for 250 springs?
Old Jul 13, 2014 | 07:33 AM
BruteFord's Avatar
BruteFord
Chevy engines, you're going to put a chevy engine in a ford pickup? I refuse to help create such an insult to Ford fans everywhere.
