EBPV delete concerns
Old Jul 16, 2014 | 10:24 AM
  #46
20powerstroke02's Avatar
20powerstroke02
Originally Posted by zdfbdfb
Maybe thread with a pipe tap of appropriate size and use a pipe plug?
I welded the pedestal shut
Old Jul 16, 2014 | 12:09 PM
  #47
20powerstroke02
Originally Posted by greg_8507
The temp range that it's kicking on; No.
The sound going away when you hit the brake; Yes
Sounds like you might have a problem with the Manifold Air Temp sensor. Which the PCM also uses to adjust fuel and timing. Which would explain your mileage problem. You need a scan tool such as AE or Torque Pro
Hey I have the intake off of the truck or spider most people call it. I looked at that AIT sensor and it's covered in oil do you think that's affecting it?
Old Jul 16, 2014 | 01:42 PM
  #48
SpringerPop's Avatar
SpringerPop
Well..... THAT certainly solves the leakage problem!
Pop
Old Jul 16, 2014 | 04:33 PM
  #49
greg_8507's Avatar
greg_8507
What about the air temp sensor thing that normally hooks into your factory air box? What if that is messed up? I'm guessing it's an air temp sensor
Yes it is. I'm sure that plays a role too.
Could be. But now that you welded the pedestal shut, you don't have a way to test it if you clean it. Atleast not without a scan tool.
Old Jul 17, 2014 | 05:01 PM
  #50
20powerstroke02
My edge says the one that connects to the air box is reading the same temperature as the outside temperature. The sensor on the manifold is a different story! I'll have to get a scan tool like you said and see what's going on with that. A new sensor from the ford dealer is $30. Other than that my parts showed up early so the truck is all back together and runs great!
Old Jul 17, 2014 | 05:45 PM
  #51
greg_8507's Avatar
greg_8507
sounds like your edge does more than I thought it would. Either way, you identified the problem. $30 is an easy repair to swallow.
Old Jul 18, 2014 | 12:12 PM
  #52
20powerstroke02
quick question before I replace this. this article says that the good temp sensor should read a few degrees cooler than the coolant temp sensor. They must be reffering to the one mounted on the spider itself ince its tucked away in the valley of the motor i can see that getting much hotter than the one on the intake box. BUT! if thats the case then shouldnt the one on the intake read much lower than the other air temp sensor? i unplugged the one on the air box and my truck defaulted to 58 degree. i will go unplug the other one and see if i notice a difference. ill play around with this for a bit.
Engine Air Temperature Sensor
thats about all the info i can find on the sensor but thats the sensor on the spider.
Old Jul 18, 2014 | 01:21 PM
  #53
20powerstroke02
nevermind i checked the resistance and my edge said 154 degree for engine oil temp or operating temp whichever they call it on there. i believe its operating. but the senor measured 7.55 ohms so i went to the chart and 7.55 ohms is roughly 140 degrees. the truck was sitting when i tested it that time. so i drove it around the block quick came back tested it again and came up with 13.something which is between 122-104 degrees. this time the edge said 162 degrees for the engine operating temperature. i'm about to take it on a decent drive then i will check it as soon as i park and see what it says but im leaning toward you are right the sensor is bad.
(im referring to the chart i added a link to in the last post i made)
Old Jul 18, 2014 | 09:49 PM
  #54
greg_8507's Avatar
greg_8507
I would have check it with a cold engine. The sensor should show about what the ambient outside temp is.
Old Jul 19, 2014 | 08:29 AM
  #55
20powerstroke02
Ok I'll try that today. Thanks
Old Oct 31, 2016 | 06:38 AM
  #56
Sigurdur Ingólfs's Avatar
Sigurdur Ingólfs
At what point is it too cold to delete the EBPV?
no worrys mate i am in iceland and it gets up to 20 below never had a proplem with cold start
B-Rad88
Jan 20, 2018 08:48 AM
bubba_3711
Feb 8, 2013 03:19 PM
bike_guy123
Jan 22, 2013 08:50 PM
jchosler
Jul 28, 2010 04:38 PM
94 1/2 stroker
18
Mar 5, 2006 03:52 AM
