EBPV delete concerns
Old Jul 12, 2014 | 03:42 PM
greg_8507's Avatar
greg_8507
Old Jul 12, 2014 | 07:03 PM
ztodd377's Avatar
ztodd377
I lived in Anchorage, Alaska when I deleted my ebpv and air intake heater. Never had any problems as long as I plugged it in at night. After a 10-12 hour shift I would just baby it until the engine warmed up a little. I just hated driving and the ebpv closing and feeling like it was sapping the power a little.
Old Jul 13, 2014 | 08:49 AM
20powerstroke02's Avatar
20powerstroke02
What are the benefits or reasons for delete the air intake heater?
Old Jul 13, 2014 | 08:58 AM
Pikachu's Avatar
Pikachu
It gives you a convenient place to put a reducing bushing for a boost gauge fitting. And you probably have a better chance of getting hit by an ocean liner on a freeway in Nebraska than you do of having the thing actually ever activate. I thought about having it activate with the glow plugs, but in the end I just removed it and plugged the port.
Old Jul 13, 2014 | 09:03 AM
greg_8507's Avatar
greg_8507
http://www.dieselsite.com/airintakeheaterplug.aspx
The bottom of this page explains the AIH. RiffRaff also sells the plug, and i've read that a cummings oil drain plug also fits.
Old Jul 13, 2014 | 06:19 PM
20powerstroke02
Wow I never knew that.... What is the point in it then?!?! For looks?! Maybe I should remove that also! Simplify my truck some more.
Old Jul 13, 2014 | 06:23 PM
20powerstroke02
I never knew any of that. I guess I'll delete that also. And when you say cummins oil drain plug is it specific to which cummins engine? I just happen to have a junk 12 valve cummins oil pan laying around I can rob.
Old Jul 13, 2014 | 06:38 PM
Pikachu's Avatar
Pikachu
I got a plain steel plug at a hydraulics shop for a few bucks for mine. I don't remember for sure, but I want to say it's an M22 x 1.5 mm.
Old Jul 13, 2014 | 07:13 PM
greg_8507's Avatar
greg_8507
I've never worked on a cummings so i really don't know. But if you have it lying around it's easy to find out.
Old Jul 13, 2014 | 07:56 PM
greg_8507's Avatar
greg_8507
You know... The more I look at the pic on Dieselsite.com, the more their gasket looks like an oil plug gasket.
Old Jul 14, 2014 | 12:00 AM
retiredsparky's Avatar
retiredsparky
If you wanted a cheap permanent fix, epoxe works in that location too. It is unlikely that this part will ever be something that the majority of 7.3 owners will "have to have".
Old Jul 14, 2014 | 08:39 AM
Justin03PSD's Avatar
Justin03PSD
When I pulled my turbo to do the compressor housing, I also did the blank pedestal and high flow outlet. I was really happy with how it turned out.
Old Jul 14, 2014 | 10:39 AM
  #28
20powerstroke02
Some people on other forums are claiming that if you plug the pedestal and don't go with a blank one it will starve the turbo from oil. That doesn't add up to me because all I'm doing is gutting the pedestal oil flows through it regardless..... Or am I missing something? I'm going to see if this cummins oil pan plug works here in a second.
Old Jul 14, 2014 | 11:17 AM
  #29
greg_8507's Avatar
greg_8507
If you plug the wrong port, you can cut off the oil to the turbo. The thread I linked in post 20 explains how the oil runs through the pedestal. If you follow that, you'll be fine.
Old Jul 14, 2014 | 11:37 AM
  #30
sowaxeman's Avatar
sowaxeman
The plugging of the wrong port and affecting oiling....I assume you are referring to the EBPV portion of this thread, not putting the plug in place of the AIH that is being talked about here too?
