New Glass
Old Jun 1, 2015 | 05:14 PM
pbsdaddy's Avatar
pbsdaddy
New Glass
Had all the side glass installed today. State didn't care for the tinted stuff that was in there. I am so glad I had a glass guy do it. The glass was glued in. He had to use some special knife like tool to cut away as much of the glue as possible. The he pried and pulled until it cam out of the track. I don't have a motorized knife like tool!
I had ordered the tape and new seals, along with the glass, just in case. He said no one uses tape any more, unless they are going for full concourse. Seems the glue in method is the norm these days.
Of all four pieces, he was able to extract one without chipping or cracking. Yeah, it was worth the $130 dollars.
Old Jun 1, 2015 | 07:15 PM
abeagle's Avatar
abeagle
Need to replace at least one of mine which are already clear glass. Just for planning purposes - How long approx. did it take to do the job?
Bruce
Old Jun 1, 2015 | 07:19 PM
pbsdaddy's Avatar
pbsdaddy
Three guys working, each doing a particular portion of the job. They were here about 3 to 3.5 hours. Most of that time was spent removing glass from the frames and cleaning out the frames to receive the new glass.
Old Jun 1, 2015 | 10:12 PM
drptop70ss's Avatar
drptop70ss
I will be using the cork style setting tape with my side glass, as you found out urethane is pretty much permanent.
Old Jun 2, 2015 | 05:02 AM
pbsdaddy's Avatar
pbsdaddy
Be careful Dave. It's easy to see why glue is the preferred method when one starts to push the glass into the frame/track. It's a tight squeeze and without equal pressure across the entire pane, it could easily crack.
Old Jun 2, 2015 | 09:27 AM
lowtrkn2k's Avatar
lowtrkn2k
Sounds like it was well worth the cost. I bet there wasn't much profit in the end with 3 guys and taking 3.5 hrs. The next guy may not get so lucky!
Old Jun 2, 2015 | 10:05 AM
edzakory's Avatar
edzakory
I have to install a new tinted big back window since I cracked the glass while installing it myself. I was quoted $60 for the install (with ss trim) but the killer is the $550 for the new glass. I am out of the glass install business.
Interestingly, I had two small garage windows and two regular house windows installed the other day. Installation was $350 for two guys and they were done in 45 minutes.
Old Jun 2, 2015 | 03:00 PM
pbsdaddy's Avatar
pbsdaddy
I supplied everything but the glue. But, even at that, there sure wasn't much meat left on the bone. I'm sure they figured 1 1/2 to 2 hours for the job.
Old Jun 2, 2015 | 03:03 PM
pbsdaddy's Avatar
pbsdaddy
See if you can find someone who will do the install if you provide the glass. I'm sure that is where a lot of their profit is. LMC has most, if not all, the glass for our trucks. Cost was fair and shipping was reasonable.
It looks like they have your window for $189
http://www.lmctruck.com/icatalog/fa/full.aspx?Page=28
Old Jun 2, 2015 | 03:35 PM
edzakory's Avatar
edzakory
I checked their catalog and I don't believe they sell the dark limo tint; the smoke tint isn't dark enough for the AZ sun. However, I plan on calling them to make sure and to determine the delivered cost. The two quotes I got for the dark limo were $550 delivered.
I did find someone local who will replace the glass and trim for $60, but I have to supply the glass and new gasket. It's well worth it but they will not guarantee against breakage. However, I don't believe they will be hitting it with a "rubber" hammer like I did.
Old Jun 2, 2015 | 05:10 PM
pbsdaddy's Avatar
pbsdaddy
Short of having a matching tint available, you could have a local shop add more tint once installed. That shouldn't cost more than another $35 to $50. And I'm sure they could do a real good match.
No, I don't see too many glass people using hammers of any kind!!
Old Jun 2, 2015 | 08:54 PM
drptop70ss's Avatar
drptop70ss
These guys sell glass with or without different tints. I had them make the glass for my 1937 buick, they had the templates and everything fit excellent, very fair prices as well. I also ordered gray tinted glass from them for my 51 F1 #2 and they said they can cut the glass for my chopped top truck #1 if I send them patterns.
classic-auto-glass on eBay
bryanmartin
Sep 5, 2018 06:38 PM
slowrollerzcustoms
Jul 12, 2014 01:14 PM
Walston
Mar 5, 2006 12:53 PM
bigric
Oct 13, 2004 09:51 PM
