So conversions? What would be the easiest?
Well guys,
I haven't been on here much lately. I haven't had many truck problems, aside from the crap radiators I bought, and I have been real busy. I have been keeping my eye out for an OBS crew cab 4x4 IDI auto, but it has proven to be harder to find than a unicorn with two peckers! Here is a question for all of the conversion veterans out there. What would be the easiest to do? Convert a gasser OBS crew cab to diesel?
For instance:
F350 FORD 4X4 CREW CAB
or
1994 FORD F350 CREW CAB
or
93 Ford F-350 Crew Cab 4x4
Or use my 94 4x4 Supercab to convert a 2wd diesel to 4wd?
If I went with the gasser, I could use the motor and trans from my 94, or the motor from my 93 and find another E40D 4wd IDI trans which I see often, or just pick up something like this:
7.3 IDI Diesel & E40D Transmission
if it is from a 4wd.
I want a CC real bad, but I cant find an IDI.
Are there any other conversion options?
I know I can get an 8th gen and swap front clips, but I cant find one of those either.
Thanks,
Mac.
For instance:
or
or
Thanks,
Mac.
Don't you have to have a diesel VIN to avoid major headaches with emissions testing in Colorado? I don't know, I'm asking. I would avoid stepping in that pile o' poo at all costs. Of course if is not an issue putting your '92 engine into this would be pretty cool...
1989 ford 4 door bronco
1991 Ford Centurion Bronco
Ford those pop up from time to time and most of them have IDI's in them. This one is pretty clean.
Look for a stroker with a bad engine or trans or something.
Whereas a power stroke.... drop in IDI, pull out ecu and wiring.
How is that not easier?
Seriously? You answered half your own question. On a gasser you would have to swap fuel lines, tanks, dash cluster and wiring, engine mounts and wiring. Gasser has a lighter frame (f250) and usually smaller u-joints.
But my definition of a pita is when you have to fab and modify stuff. Where bolt in is just time consuming.
I don't know about emission's testing they don't require it out here, but my 93 is titled as a gasser with a diesel vin and nobody seemed to care.
on
if you found a psd 4wd crew cab with a blown engine,you wouldn't downgrade to the idi imho lol.you would be better off just setting another psd in.i know there are fearful people in the idi world of electronics but the 7.3l psd's have proved themselves just as reliable as the idi's with more power right out of the gate to boot.
the crew cab 4wd setup is a pricey combo no matter how ya slice it anyway.
id go with the 460 4wd crew to idi swap.460 pigs are a dime a dozen now cus no one can afford to drive them anymore.sure it's some work,but it's not complicated and would make an enjoyable,affordable project.
dlp38910
04-29-2012 08:33 AM
