Modular V10 (6.8l)
Help with spark plug issue?
Old Jul 10, 2014 | 11:04 PM
johnsland8's Avatar
johnsland8
2001 F-350.
Driving along, heard a loud pop and then had a misfire. Found a broken coil on plug second from back on passenger side. As you know this is a PIA to get to and you can't see in the hole so you can't see the plug. Bought a new coil pack but for the life of me couldn't get it on. Stuck my cell phone back in there and shot a picture down the hole...
So that's what I see in the picture. I can't move the plug by hand so it's not loose.
If anyone can provide any tips on what I should do? I would greatly appreciate it...
Thank You!
Old Jul 11, 2014 | 06:35 AM
projectSHO89's Avatar
projectSHO89
Spark plug blowout.
You'll need an insert (Timesert, Lock n'Stitch, etc) installed to repair. Do NOT use a helicoil or the cheap Dorman kit.
Old Jul 11, 2014 | 10:23 AM
Wolfboro's Avatar
Wolfboro
Try a long needle nose plier to remove the old plug . It must have been blown out of its threads in order to break the COP coil sitting on top of it . It is possibly wedged in , just try to pry it out .
Use one of the repair kits suggested by projectSH089 to repair the spark plug hole.
Go to (www.timesert.com) for more info.
Good luck,
Old Jul 11, 2014 | 10:32 AM
johnsland8's Avatar
johnsland8
Originally Posted by projectSHO89
Spark plug blowout.
What do I do about getting it out? It's wedged in there against the tube so I can't get a socket on it... Should I assume I can't do any more damage by prying it over enough to get socket on it?
Also, this cylinder has limited access and no visibility. Am I going to be able to get a TIME-SERT in there where it sits?
Thanks for the help!
Old Jul 11, 2014 | 10:55 AM
johnsland8's Avatar
johnsland8
Sorry, didn't see Wolfboro's post. I was on the page when he posted and didn't refresh...
Thanks!
Old Jul 11, 2014 | 11:53 AM
Wolfboro's Avatar
Wolfboro
some individuals bought a "bore scope " to see the threads and possible debris in the cylinder . Check Harbor Freight for a low cost bore scope . Read the info at timesert website.
Good luck,
Old Jul 12, 2014 | 05:37 AM
CPaulsen's Avatar
CPaulsen
Had the same plug go on mine.....installing the insert is not bad......had to take mine to a shop to have it done since I was on vacation....charged me 285.00 to have it done.
Old Jul 15, 2014 | 10:42 PM
Cardinal Puller's Avatar
Cardinal Puller
Did all 10 of mine. All are access able Passenger side easy, driver side the back two are a little tough. There is a bracket on the firewall you can remove easily to get more room.
thegreatgate
Apr 4, 2016 09:06 AM
grizz 454
Nov 24, 2014 07:34 PM
Plain Jane
Oct 8, 2011 04:50 PM
rkedz
2004 - 2008 F150
92
Jun 23, 2009 09:24 AM
screwyou32
1997 - 2003 F150
15
Dec 30, 2008 01:40 PM
