Speedo needle problems
Old Nov 14, 2004 | 03:24 PM
Tailhunter18's Avatar
Tailhunter18
Unhappy Speedo needle problems
I just replaced the speed sensor on my 4x4 1995 F-150...the needle was orginally jumping and after i replaced the speed sensor it did the same thing....It does it all the time...Any suggestions would be helpful..
Thanks, Will
Old Nov 17, 2004 | 10:31 PM
TONINA's Avatar
TONINA
You Have To Inspect Also The Sensor Ring.
Inspest If All The Teeth Of The Speed Sensor Ring Are Ok..
Old Nov 17, 2004 | 11:06 PM
MustangGT221's Avatar
MustangGT221
It could be the rear end tone ring, or the actual speedometer itself. To learn more, do a search under "bad PSOM".
Old Nov 18, 2004 | 10:58 AM
Tailhunter18
Thanks guys for the input i'll check into it!!!
