'95 hard start after warms up
Old 07-09-2014, 10:05 PM
mitchell390's Avatar
mitchell390
mitchell390 is offline
Some Info about my pickup, 1995 ext cab long box, ZF5, bully dog cold air intake, 3.5" down pipe to 4" out, 125K miles, new glow plugs & relay within last 2k miles.
my 95 will start up fine when it has'nt been ran, but some times after you get it up to operating temp, and shut it off, itll start, then sputter and die. It doesnt cranks longer then usual, does not smoke while it cranks, and some times itll do it 2 times but after the 2nd time it always fires up and idles fine, runs great once you get it started.seems to be progressivley getting worse, also seems like it maybe smoknig a little more under heavy acceleration
may be a coincidence but i just reflashed the PCM, with Fords IDS computer, and ever since then it seems to be acting up.
thanks
~bryce
Old 07-09-2014, 10:33 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Hard starts when warm most the time point to bad ipr o rings. But maybe some thing went wrong in the reflash too. Why did you get it reflashed in the first place. Was there a problem befor?
Old 07-09-2014, 10:50 PM
mitchell390
Had no problems before,but i had access to the ford IDS computer so i didnt figure it would hurt it any by reflashing it.
cabloom300
11-05-2018 11:42 AM
SGorman13
30
02-26-2014 05:26 AM
ozzy460
12-31-2010 10:23 AM
bpiazza
06-30-2010 01:26 AM
MRBASS
02-05-2004 07:06 PM
Quick Reply: '95 hard start after warms up
