frame and motor mount ?'s
Old Jul 9, 2014 | 12:11 PM
redneck_rolemodel's Avatar
redneck_rolemodel
I don't know but have heard lots of different things and was looking to clarify some of them.
400M motor mounts the same for the 300 I6 (towers and all)???
in 77 or 78 the front half of the frame is wider than the older ones???
In the next 2 days I will be finishing up my 300 I6 into my 78 bronco and was looking to see if these were going to be issues...
Old Jul 9, 2014 | 02:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No such thing as a 400M, it's just plain 'ol 400.
Same engine supports aka towers, stands, perches:
1969/79 F100 302 / 1975/79 F150 302 / 1977/79 F100/350 351M/400 2WD
Beginning in 1973, Ford increased the width of the inner frame rails behind the cab on F100/250 2WD's to 37 1/2."
Last edited by NumberDummy; Jul 10, 2014 at 02:10 AM. Reason: Highlighted the engine sizes in red.
Old Jul 10, 2014 | 12:40 AM
moonley's Avatar
moonley
I plan to do the same and have looked into it myself; as I understand it 300 and FE engines use the same engine supports. It should be relatively easy to get FE engine supports in most any junk yard from a 70's 4x4 pickup to swap in your Bronco.
Old Jul 10, 2014 | 01:07 AM
redneck_rolemodel
Thanks for the input. That is my bad I thought that the 400 was a "M" motor, but is good to know. That is good to know that the towers are the same. I just need to move them forward to the next set of bolt holes? I know that as it is right now they are too far back. I still have the towers in the bronco from the 400 but they seem to be too close to the bell housing for putting the 300 in.
Old Jul 10, 2014 | 01:26 AM
redneck_rolemodel
Numberdummy,
I have some more questions maybe you could help me with if you would please. I have a 1978 F600 wrecker with the big 6 hole lug pattern. I am looking at a F800 that I can get as a parts truck. The F800 has the Open center "California" wheels and was wondering if the front axle and spindles were the same. I lost the wheel bearings on mine going down the road and ruined the hubs and spindles but have another set of hubs. I was curious if my other F600 hubs would fit on the F800 spindles?
Old Jul 10, 2014 | 01:33 AM
NumberDummy
Originally Posted by redneck_rolemodel
Numberdummy,
I need the AXLE code that is stamped on the Warranty Plate, also the GVWR and the size of the brake shoes, as there are 4 possible sizes for F600's, 11 (!) possible sizes for F800's.
Old Jul 10, 2014 | 01:52 AM
moonley's Avatar
moonley
No, I think you misunderstood the posting. The 300 will NOT work with your 400 towers. According to NumberDummy's post the 302 and 351M/400 2WD share towers for the years he specified (note the 300 is not included in his list). From what I know the 300 shares towers with the "FE" series of engines, such as the 360 and 390. You also cannot use 2WD 300 towers in your 4WD Bronco.
Lastly, to address the "and all" portion of your original question, you will still need the 300 motor mounts as the motor mounts for the 400 or FE series engines will not work, but you really should buy new motor mounts for an engine swap anyway (new motor mounts for both sides should only cost $20 or $30).
Old Jul 10, 2014 | 08:00 AM
redroad's Avatar
redroad
If the 300 I6 is going into a 4wd you will need a rear sump oil pan as well with P/U tube with mounting stud, dipstick, dipstick tube, and possibly an oil pump for the rear sump oil pan ..
Old Jul 10, 2014 | 01:26 PM
redneck_rolemodel
It is going in a 4X4, I don't think they made the big broncos in 2WD. It came out of a 4X4 pickup so it is good to go for another 4X4 chassis.
I have another set of towers out of a 390 truck so I may have to use those. Thank you everyone for the help on which towers to use.
7379ford
Engine Swaps
Apr 29, 2025 07:17 AM
havi
Engine Swaps
28
Apr 18, 2011 02:15 PM
JustBlaze
Nov 16, 2010 08:04 AM
tdmoparguy
18
Jan 27, 2010 08:45 AM
old75F-100
Nov 16, 2005 08:18 AM
