Countour Bumper "finish panel"?
Old Jul 9, 2014 | 11:37 AM
benbuilder's Avatar
benbuilder
1975 f100 Ranger XLT. It has a contour bumper. I have a parts truck that has a better contour bumper and brackets which I switched over. The old brackets had a hole drilled in each of the brackets on top, and a piece of sheet metal was bolted into the top of the bumper (chrome bolts) from end to end, so that visually a person could not look through the space between the bumper and the bed. It was painted the body color and had rubber edging on two sides. It seems to be something manufactured and not home made. I have looked on line, the shop manual, and at this site but cant find any information. I am not building a show piece but would like to do what is correct. Thanks
Old Jul 9, 2014 | 11:43 AM
mikeo0o0o0's Avatar
mikeo0o0o0
No, there's no filler panel that goes between the top of the bumper and the rear of the bed.
Here is the illustration from the Ford parts catalog.
File Type: pdf
Old Jul 9, 2014 | 11:45 AM
benbuilder's Avatar
benbuilder
Thanks Mike
Old Jul 9, 2014 | 02:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Only 1978/79 Bronco's have a rear filler panel (17808 stone deflector).
The chrome contour bumper is the same as 1973/79 F100/350's with 37 1/2" rear frame rails (D3TZ-17906-A), but the Bronco bumper brackets are not the same.
Old Jul 9, 2014 | 02:28 PM
gumshoe's Avatar
gumshoe
I made one for my 74 F100 cuz I did'nt like looking at the brackets. I made it of about .032 sheet metal that I found at home depot, it has a flange bent on one side, as I dont have a brake. I made end pieces that form around and match the ends of the bed. I mounted it under the bed to the cross piece with sheet metal screws. looks slick.
72XLT
Sep 16, 2006 11:51 AM
locknload
Jan 30, 2006 11:10 AM
71cc
Mar 10, 2003 11:55 AM
Sycostang67
Feb 17, 2003 07:56 AM
jryter
Oct 30, 2002 02:28 PM
