SHOULD I JUNK IT????
Old Aug 19, 2014 | 08:09 AM
Tectron1's Avatar
Tectron1
That's Awesome, I'm glad that my video's were able to help you get up and running again.
Old Aug 19, 2014 | 08:55 AM
BigSix1's Avatar
BigSix1
Wonderfully-inspiring video, Tectron1.
OP--Good for you! I filed this vid. for future reference.
Old Aug 19, 2014 | 08:56 AM
Phil Woolfson's Avatar
Phil Woolfson
I may be a bit carcentric (given the way people are often nowadays, who can blame me) but it would seem that if people are willing to buy a rusty old model T and turn it into a museum piece, then anything with a halfway decent body and straight frame with a motor that turns over and a tranny that spins the wheels is fixable. I can tell you first hand that most parts are readily available for our trucks, and if you are mechanically inclined and have internet access, you are more likely than not most of the way there as soon as you have the truck in your driveway.
Old Aug 19, 2014 | 10:18 AM
Encho's Avatar
Encho
The Southernmost Mod
I knew it was the ECM, when everything runs fine, then all of the sudden so many thinks start failing it's either a wiring deal or the ECM itself, I'm glad you found the cause.
Old Aug 19, 2014 | 01:34 PM
Old Trusty's Avatar
Old Trusty
So did you do the repair like the video showed or pull the ECM outta the jy?
Old Aug 19, 2014 | 08:23 PM
Tectron1's Avatar
Tectron1
Thanks! I'm glad its helping people.
Old Aug 19, 2014 | 09:49 PM
krooser's Avatar
krooser
I think you may have found a cure for many un-curable problems that nag some owners…
My son must have spent $5K (three rebuilds) trying to repair nagging erratic shifting problems in his Ram with a Cummins diesel only to find a different ECM with a software update fixed the problem.
Rollerz70
Aug 14, 2018 09:36 PM
rollinginmudgirl
Nov 5, 2009 05:58 PM
lone_star_bronco
1978 - 1996 Big Bronco
Feb 3, 2003 02:49 PM
bigbluebronco43
Nov 20, 2002 12:25 AM
