Flareside Compatability Question
Old Jul 8, 2014 | 11:19 AM
johnmel59's Avatar
johnmel59
I've asked before but never got a clear answer so lets try again.
Will a 6 1/2 ft 1953-56 Flareside bed fit on a 1965 chassis? Can I use the exisitng cross members from my '65 Flaresdie bed on the 53-56 bed?
Thanks in advance for your info!
Old Jul 8, 2014 | 02:56 PM
rusbukt's Avatar
rusbukt
See if this will help ya.
1956 frame dimensions.
http://restoreyourford.com/images/19...3tdims0003.jpg
In 1965 the Ford truck chassis was all new.
https://c2.staticflickr.com/4/3562/3...ce30c807_z.jpg
I'm thinking some fabrication would be necessary.
Old Jul 8, 2014 | 08:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 1965/66 F100 2WD frame is only different inre to Twin-I-Beam suspension and how the engines/trans' are mounted, behind the cab it's the same 1961/66.
9" rear axle and rear leaf springs same 1957/67 F100.
The only difference might have to do with the wheelbase. 1953/60 F100 with 6 1/2' bed: 110 inches. 1961/66 with 6 1/2' bed: 114 inches.
Old Jul 8, 2014 | 09:06 PM
rusbukt's Avatar
rusbukt
Frame width is the same. Back of cab to center of axle is same. Only problem might be the cross member mounts location. I'll bet some 1/4" flatbar could fix that real easy.
svooom
Dec 28, 2019 09:42 PM
ctorres
Apr 1, 2018 09:31 AM
yardape1
Jun 22, 2016 09:17 PM
tomrooster-1
Nov 29, 2007 08:29 PM
The Speaker Guy
Nov 11, 2006 10:15 AM
