winch on my 65 4x4
winch on my 65 4x4
Hello all,
there was a winch mounted on my 65 4x4. I never heard of the brand and i was curious if anyone on here knows anything about it. I Googled it with little luck.
The brand of the winch is Koenig Iron Works made in Huston texas
It is a PTO powered winch with a cable controled PTO
Thanks,
Sam
Thanks,
Sam
so I did some work research and found this link it is about the winch kinda interesting that the winch dates back to the early 1950's and was used mostly on jeeps, I wonder how it found its way on my 65 4x4...
BUYING KOENIG PTO WINCHES | eBay
Hello all,
Thanks,
Sam
Thanks,
Sam
I know it is late, but what do you wnat to know about this winch.
It is a great winch and you can still get parts for it.
Send me a mail at: lars@koenigwinches.dk
Regards
Lars
Hi Bob
The winch you have will be a 12000 lbs winch on the 1st layer
It should hold up to 145 feet of ½ inch cable in 4 layers, but might have more I run a 8000 lbs (recommended length 145 feet) but with 200 feet on the drum.
Depending if it is a mechanically or hydraulic winch the linespeed will be between:
Mechanically:
31 fpm (1st layer) and 53 fpm (4th layer) with 900rpm on the input shaft.
Hydraulic:
12 fpm (1st layer) and 20 fpm (4th layer) with a flow og 15GPM. Could properly be different, depending on the hydraulic pump and motor
Gearing will be 32:1
If you need parts, please give me a call
Lars
thanks for that Lars, i hadnt realized you had gotten back to me so quickly on the Ford site, no one else knew anything about that particular Koenig winch! thats why i figured for certain things, the pirate 4x4 site would be good to become involved with.......Cheers, and a Happy New Year to you, if i need parts in the future, i will contact you!!!
