Starter will not stop!
Old Dec 2, 2004 | 08:39 AM
dwoxford's Avatar
dwoxford
Cool Starter will not stop!
I started my 1988 f-150 truck and the starter would not stop turning. I turned the key off pulled it out still turning i had to disconnect the battery. As soon as i hook the battery up the starter starts no key needed. any help would be great
Old Dec 2, 2004 | 08:47 AM
Spaznaut's Avatar
Spaznaut
Usually the starter thingy (couldn't spell it this morning) on the fender. Could maybe be the switch under the steering column.
Old Dec 2, 2004 | 08:55 AM
dwoxford's Avatar
dwoxford
i have replaced the starter key lock cylinder and relay
Old Dec 2, 2004 | 08:58 AM
EPNCSU2006's Avatar
EPNCSU2006
It's likely the solonoid on the fender is stuck. Unplug the small red wire and see if it still does it. If you plug in the small red wire and it immediately hits the starter, then there is a problem between the solonoid and the ignition switch - somehow the wire is getting 12V. If it runs the starter with the small red wire unplugged, then you should go get a new starter solonoid/relay.
Old Dec 2, 2004 | 02:31 PM
dwoxford's Avatar
dwoxford
That fixed it!! Thank you so very much
Dwoxford
Old Dec 2, 2004 | 06:17 PM
Spaznaut's Avatar
Spaznaut
Had that happen to my Mustang while sitting in a drive-thru. Kewlness factor went to neg 10 Luckly my battery cable wasn't tight and man was it hot.
Fredf250
Jan 23, 2013 08:02 PM
justplumducky
Aug 28, 2010 08:24 PM
jhoopman86
1978 - 1996 Big Bronco
Aug 4, 2010 09:30 AM
ridecolby
Aug 11, 2009 07:51 PM
